20 Most Recent
Infogrames Thomas and Friends Railway Adventures Playset for Windows Questions & Answers
Thomas & Friends Railway Adventures
If it worked on Windows 7, it will definitely work with Windows Vista
The only thing you need to check is if its Vista 32-bit or 64-bit - the latter is known to be not compatible with a lot of software.
Have a 2001 version that won't install on windows
This is not true. There are a couple of things you can try. One is to try installing the software in XP Compatability mode. Run the install as an administrator.
If that fails, you can certainly get it to run if you use some free virtualization software (VM) to create an instance of Windows 98 or Windows 2000 on your computer and then install Thomas inside this virtual machine.
Font size setting
There has to be an option in game menu. Pause the game and have a browse through
CAN OR IS THERE A
If you mean Deer Hunter 5: Tracking Trophies, then there is hope. That game is meant to run on Win 95, so XP can play it. All you need to do is enable Program Compatibility. Use the link below from Microsoft's website to walk through the process, and you should be hunting Buck in no time.
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/appcompat.mspx
