20 Most Recent
ValuSoft Hard Truck: 18 Wheels of Steel for Windows Questions & Answers
Password for hard truck
From what I remember of this game.that I own but abandoned since windows xp.. You don't need a password. If you downloaded this game from a direct website..you may have fallen into a SPAM trap..that downloads junk programs and ads on your PC. go to valusoft.com for more information/links to legitimate sites to download game.
I want cheat codes in a game called hard truck it
hi atul, there are cheats for this game, but they involve modifying the files in the game,which can be quite tricky. if you do want to put cheats on the game search for "cheats for 18 wheels of steel hard truck " on a search engine{it starts with a g} and click on the first link-it will tell you in detail how to insert the cheats into the game files. i hope this has helped you,bye!
Gyjs
derit
make sure your flash player is up to date and make that the bit on that game supports your computer for example if you have a 32 bit you want be able to 64-bit.
The downloaded game 18wos contains split files.
downloaded games are a bit tricky you need to create a virtual ISO drive to mount the game to so the computer thinks it is a cd, this is a quite simple process just stuff around on google for a bit and find and ISO mounting program there usually free
When trying to load Big
Issue:
When attempting to run my software I get the following error.
The application failed to initialize (0x0000135). Click to terminate.
Solution:
Your PC is missing the Microsoft .NET framework which most newly developed software will have.
Here is the fix right from Microsoft.http://msdn.microsoft.com/en-us/netframework/aa569263.aspxSTEPS1. Click on link above
2. Clink on Install Now.
3. download
4. Run it
5. Install, and follow on screen prompts
6. restart comptuer
please be sure to rate me, recommend me if you feel like i have been helpful.
Game won't work on my windows vista computer?
I have two suggestions to try. First, go to the shortcut or .exe for the game, right click on it and go to properties. Click on the compatibility tab and check the box for "Run this program in compatibility mode for:" and Windows XP should already be selected. If this doesn't work, also in compatibility there is "Run program as administrator". Only do this with programs you trust, but I don't see a reason not to trust this game. If this also does not work, if you are running 64 bit vista, it is likely the game will not run at all. This has to do with it being a 64 bit operating system and not a 32 bit operating system, not if it was vista or XP. I hope this gave you the answer you were looking for.
Game not downloading
maybe the game is scrached and if it is you could bring it to a game shop to get it cleaned. and they also sell disk cleaners at fred meyers and other stores(I prefer the electric ones)
If you cant afford any of this you could use windex but i do not really recommend it.
and if you have the receipt you could take it back.
and try it in another computer maybe your devd drive is broken or uunplugged
