20 Most Recent
HIP Medal Of Honor: Airbourne for Windows Questions & Answers
Can not install game
Had same problem. Go to Control Panel/Programs and Features and uninstall the NVIDIA agia physics drivers. Then try installing the game again and it shoul dwork fine. I think the problem is that you have a later Agia Physics driver on your PC than what is on the Medal of Honor disk. What advise against uninstalling windows and all that malarky - just do some research.
Problem with Ati radeon graphic card
The ATI Radeon X1050 video card is unfortunately not supported by the game. You need atleast a X1300 to play the game. But you may try updating the game itself by going to the medal of honor website and download the patch. Then restart your computer and try starting the game.
Freezing
Hi barryj_vecto,
It could be one of the two problems: either the game you have is faulty or the game installed incorrectly. Now I assume you have a decent computer that can run this game and theres no problem playing it, try re-installing the game and trying again (save your saved games elsewhere so that it's not ereased when uninstalled). If you still have the problem after reinstalling thje game then it's the game itself that is faulty, claim your vendor to change the game (if you bought it) or download it again (if you downloaded it).
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
Well i got the new
Unfortunately, your Logitech controller uses the DirectInput control standard, and Deathly Hollows Part 1 will only work with the new XInput standard introduced in Windows 7. The only Xinput controller so far is a 360 controller hooked into the PC. There are also some software emulation solutions, but those can be a bit tricky and buggy to use. For the best experience, I'd recommend purchasing a 360 pad and the corresponding wireless sensor.
