Your keyboard has been set 'on' mode with 'AI'(Artificial intelligence; to input letters and language automatically for your ease), it is interrupting your combination of arrow keys to work in Cricket 07,
please try after off mode all options for typing setting under keyboard
give a try at torrents............. try a verified torrent... nowadays u get cracked ones so it must not be a big trouble getting'emcheck out www.torrentz.eu or www.kat.ph or www.thepiratebay.orgIt must wrk out
If the game didn't originally have a commentary in it, you probably won't be able to find a commentary file, because from a programming standpoint the code would actually need to be rewritten to have it.
For example, if you scored a goal, a pointer in the code would have to activate, or point to, the "Goal!!!" sound for it to work.
The problem is due to the "bats.xml" file is not correct. Assume some bat number is assigned to a batsman using the editor and that bat number is not available in the game directory.then it will lead to the error as said by you.The solution to this one is the "bats.xml" in the game directory and editor directory should be the same. Do remember different patches will have different bat names in the "bats.xml"
If the message you are receiving is something like"Cricket07.exe has encountered an error, and needs to close. We are sorry for the inconvenience" etc, then this is most likely due to outdated video card drivers. Update your drivers to the latest version for your card, and then try the game again. Hope that helps. Cheers from NZ :D
