20 Most Recent
CDV Software Blitzkrieg for Windows Questions & Answers
My Blitzkrieg doesn't work on
I think this is a common problem as Vista does'nt support many games and softwares...........Its better to use Win 7 friend.........
I've uninstalled and re-installed Blitzkrieg
Try updating your video card drivers. However, according to the specs, it's not supported for vista.
Vista site is equally unhelpful.
http://www.microsoft.com/Windows/compatibility/windows-vista/Details.aspx?type=Software&p=Blitzkrieg%20Anthology&v=CDV%20Software%20Entertainment&uid=&pf=36&pi=6&c=PC%20Gaming&sc=Strategy&vd=all&os=64-bit
Had a quick browser on the forums. Have you tried this vista dual-core patch?
http://bkpforums.com/phpBB2/viewtopic.php?f=58&t=3275&p=108961&hilit=screen+map+vista#p108961
Best of Luck
I have tried everything, how
This is an older game so it may not be possible, but there are a couple things I would try. I have linked to sites with a full description of what is needed for each suggestion.
Compatibility Mode and Set CPU Affinity:
http://techpaul.wordpress.com/2009/06/28/compatibility-tricks-for-old-programs-new-machines/
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
patch your game:
http://www.fileplanet.com/124619/120000/fileinfo/Blitzkrieg-v1.2-Patch
A quick search found other users who got Blitzkrieg to work, but I found none that were using Win 7 64 bit. 64 bit versions of windows seem to have more compatibility issues with older software than the 32 bit.
Assuming you have tried all of this, you might consider a dual-boot option for Win XP, or get an older PC for this and any other Win XP games (that don't like Win 7). I have found several of these.
Why cant i install blitzkreig
try installing your game in compatibility mode.
Running from a disc:
right click on disc>open>(find the installer for the game usually installer.exe)>right click on the installer>properties>compatibility tab>(click the box to run in compatibility mode and try running your software with XP SP3).
If you are installing from a file then just follow the same steps, find the installer in the downloaded folder...............
