20 Most Recent
Autodesk AutoCAD 2004 for PC Questions & Answers
How to install autocad 2004
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Is there any chance to
Maybe. Typically 32 bit programs will not run under 64 bit processors, but some will run under compatability mode. Navigate to the program and right click on it and specify run in compatability mode. Some older programs will not run under 64 bit, period.
Autocad 2004 win7
pleas do not install any antivirus after the instalatio of window s 7 after installation of window 7pleas install all the softwere that you need to use and then install any antiviurs i hope all the softwere or programs work properly
Autocad drawing in winxp cannot opened in vista
Yes, Its same as you saved MS word or any other office files in latest MS Office 2007 format and try to open in 2003 format. For your future use with all the office related and other softwares you should always try to save two files viz a viz one in the format which your sofware gives by default and the other in the older format which you will have to manually scroll down after saying Save as in your document below the box in which you type the name on which you want to save your file. You will get many options there just check the version of your school autocad and save it according to that version. If you can't go to the school now for checking. Just save diag1, diag2, diag3 .... likewise for all the available formats in your pc one of them will deffinetly open at your school.
Thankyou for using fixya free utility kindly rate my solution.
