20 Most Recent
Behringer C-1U Usb Large Diaphragm Condenser Microphone - C-1U Questions & Answers
Behringer Europower Pmp1280s, remove front panel
To remove the front panel of the Behringer Europower PMP1280S, you may need to follow these steps:
1. Ensure the device is powered off and disconnected from any power source.
2. Locate all the screws that secure the front panel to the chassis. Based on your description, it seems you have already removed the screws on the front side and the ones on the frame.
3. Sometimes, there may be additional screws hidden beneath labels or rubber feet. Carefully inspect the front panel for any hidden screws and remove them if present.
4. Once all the screws are removed, gently try to pull the front panel away from the chassis. It might be snug due to connectors or clips holding it in place.
5. If the panel still appears to be stuck in the middle, double-check for any screws that may have been missed or hidden. Make sure you have removed all the necessary screws to fully release the front panel.
6. If the front panel remains stuck, do not force it as it could potentially damage the device. Instead, consider consulting the user manual or contacting Behringer customer support for specific instructions or further assistance.
Remember to exercise caution when working with electronic equipment and always refer to the manufacturer's instructions or seek professional assistance if you are unsure.
6/20/2023 7:09:13 PM •
Behringer...
Answered
on Jun 20, 2023
Our new Behringer 2000 has stopped working. The green light doesn't come on when sound goes in microphone.
the green light is power indicator not mic level. the green light should come on when powered up. remove mike cable and the see if green light comes on, If it does power down and connect mike and cable (hopefully you have a good quality one and not a toy)
Call Behringercustomer service. Where did you buy it from, if new it is under warranty and need to replaced with another new one. It is not an audio mixer the yellow and right lights are for clipping.
6/9/2022 2:46:07 PM •
Behringer...
Answered
on Jun 09, 2022
B300 parts list
Have you tried going up on Behringers web site? You can google the part number.
5/7/2014 4:17:55 AM •
Behringer...
Answered
on May 07, 2014
