20 Most Recent Toro 1800 Power Curve Questions & Answers
clean the gas out of it make a new batch of 50to 1 mix 2+2 oil make sure you close choke to start it and open after it starts or you will foul out the plug , when they sit the gas goes bad , make sure you are getting spark to the plug always empty the carb when stored and run it until it shuts of by itself , will last longer
Toro 1800 Power... | Answered on Dec 03, 2017
adjust the cable at the bottom will work again
Howdie go and look on YouTube They got Everything to show ya thks for your time
Toro 1800 Power... | Answered on Jan 05, 2015
https://www.justanswer.com/small-engine/97k4d-toro-lx-427-won-t-start.html
Toro Garden | Answered on Jan 31, 2020
if it has a twin cylinder engine, make sure both cylinders are firing.
Toro Garden | Answered on Dec 27, 2019
it needs fuel.
Toro Garden | Answered on Dec 04, 2019
Typical snow blower shifts by moving a drive wheel on a hexoganal shaped shaft. Likely the wheel has rusted to the shaft from insufficient maintenance.
Remove the rear/bottom cover plate to access the transmission (usually 4 bolts). Lubricate shaft/wheel with penetrating oil and work free.
Avoid getting oil on the drive wheel and disc or thoroughly clean the disc and wheel with a liberal application of alchohol until wiping with a rag comes clean.
Lubricate any drive chains as well.
Toro Garden | Answered on Dec 02, 2019
Hi Jacquelin-
I found this link.
https://www.manualslib.com/manual/772531/Toro-38588.html?page=16#manual
On page 15-16, it talks about the "Replacing the Drive Belt". This might be the problem.
Hope this helps.
Toro Garden | Answered on Nov 27, 2019
If you didnt treat fuel before storage last season then likely the carburetor is fouled. Try adding a fuel treatment e.g. Seafoam, but likely ithe carb will need a thorough cleaning or replacement.
Toro Garden | Answered on Oct 29, 2019
Let warm up if still does need new spark plug
Toro Garden | Answered on Oct 27, 2019
Try a short burst of starter fluid into the carburetor and promptly pull starter. If it runs for a couple seconds and quits then the carburetor is not delivering fuel.
If it doesnt run on starter fluid then either flooded, insufficient spark, or poor compression / crankcase leak.
Toro 1800 Power Curve Logo
6 questions posted
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
stopped working
  • Garden
