20 Most Recent
Ubisoft Rocksmith Questions & Answers
Rocksmith Guitar has no sound.
Check the battery in the guitar. May be dead.
From Ubisoft...
Can you please try to restore the PS4 database and see if that fixes the issue for you? It's similar to a computer disk defragmenter and will not affect your save data.
check the battery
1) Turn off the PS4.
2) Once the PS4 is off, press and hold the power button until the PS4 beeps twice (this may take up to 10 seconds)
3) Connect the DualShock controller with a USB cable.
4) Once connected, press the PS button on the controller. You should now see the Safe Mode options on the PS4.
5) Select option "5. Rebuild Database" and press X.
6) "The database will be rebuilt, it might take a few hours to rebuild the database" will show on the screen, press "OK"
7) Allow the database to rebuild. Afterwards, the console will return to the sign-in screen.
Tried it and it worked like a charm can now hear my guitar. And the "rebuild database" takes about 10-15 mins to complete. And all previous data in the PS4 is still there it's more of a disc defragmentation. Hope this helps
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
Well i got the new
Unfortunately, your Logitech controller uses the DirectInput control standard, and Deathly Hollows Part 1 will only work with the new XInput standard introduced in Windows 7. The only Xinput controller so far is a 360 controller hooked into the PC. There are also some software emulation solutions, but those can be a bit tricky and buggy to use. For the best experience, I'd recommend purchasing a 360 pad and the corresponding wireless sensor.
