20 Most Recent Triumph Academy Sports 400T Treadmill Questions & Answers
It is a possibility. I understand your frustration with treadmills. The P1 - P4 are programmed events. I am sure there is a way to make it just run after setting it to 3mph. Send me more information on the treadmill including name and model number...year if you know it.
Triumph Academy... | Answered on Nov 13, 2017
You have to check the Speed sensor of the tread. IF the speed senor is faulty this problem can occur. Normally in all treadmills E1 denotes the speed sensor error.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Triumph Academy... | Answered on Jun 10, 2016
Might be the power supply. That's about all I can think of. It runs but gets hot very fast and shuts down
Triumph Academy... | Answered on Jul 10, 2015
call service dept 1-866-864-3840 or downLoad it online
Triumph Academy... | Answered on Dec 28, 2014
1-866-864-3840 service Dept
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Triumph Academy... | Answered on Apr 16, 2014
Go to a locksmiths and they will cut you one if you have the old one otherwise you will need to order a new lock and key
Triumph Academy... | Answered on Feb 26, 2014
use silicones or wax read your o.manual. Adjust the REED switch, clean it, and tigh the connector very well . Of course test for open or faulty. see the diagrama
God bless youfae5e48a-3b4a-46e1-97e7-daf4cd17fef3.gif6c87d923-76bb-4cb3-a607-1be11d1fb26a.gif
Triumph Academy... | Answered on May 23, 2013
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Test it for open or faulty+ clean it, and tight vbery well the connector, see the diagram adjust it
Try to run the software calibration for troubleshooting and diagnostic too.
God bless you
Triumph Academy... | Answered on Mar 22, 2013
Triumph Academy Sports 400T Treadmill Logo
29 questions posted
Top Triumph Exercise & Fitness Experts
Mike Martin
Mike Martin
Vishalsharma
Vishalsharma
Don Eagan
Are you a Triumph Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Triumph Exercise & Fitness
Most Popular Question
treadmill runs 9 seconds stops shows e1
  • Exercise & Fitness
