20 Most Recent Tissot Prs516 T91141731 Watch Questions & Answers
Tissot prs516 & it runs fast 1 minute every day
There is a solution, but you have to wait a bit. I'll contact Tissot tmrw and then will give you advise. It's 3.15 in the morning over here, so, need a little rest.
10/12/2014 12:18:02 PM • Tissot Prs516... • Answered on Oct 12, 2014
manual
Watch is dead. There is no replaceable battery on
Hello stadler. Here is a link to a free owner manual for your watch. http://support.tissot.ch/?mod_flashPDF/id_121
Regarding a repair, the company will repair the watch. Here is a link to this information and the cost estimate http://support.tissot.ch/?mod_repair
Joe
Thanks for choosing Fixya!
11/29/2010 11:19:26 PM • Tissot Prs516... • Answered on Nov 29, 2010
Tissot prs 516 will not
This watch is described as "quartz chronograph", so it is not a self winding watch.
Go to http://www.tissot.ch/?mod_collections/action_getsubfamilies/colid_0002/famid_0012/refid_T044_417_27_031_00 for a description of the watch.
If it has stopped working, cold the battery be dead *have you had it for more than a year)?
9/28/2010 10:13:39 PM • Tissot Prs516... • Answered on Sep 28, 2010
Changing the battery
Take it to a reputable watch repair shop and let them change it for you! If you try to change that battery yourself and the crystal breaks or something goes wrong then you will have to send it back to Tissot for repair! They dont sell parts!
1/17/2010 5:18:39 AM • Tissot Prs516... • Answered on Jan 17, 2010
Where to buy a strap
you get watch straps on ebay or you can go to watch menders or market or jewlers have them
10/3/2009 2:18:44 PM • Tissot Prs516... • Answered on Oct 03, 2009
Wot size battery do I need for a t472 tissot trace
I think that's a SR936Sw or equivalent. That watch has a pop-off back, so its easy enough to access. You'll need a jewelers pincers or something like a sharp pin to extract the battery (Carefully!) as its embedded in the body.
4/9/2016 1:10:11 PM • Tissot T Watches • Answered on Apr 09, 2016
What is the reason my new Tissot watch is not working, which was bought in switzerland this year January?
If your watch is battery operated, the most common reason is battery itself. Don't mind it was bought in January, because watch itself could be in shop storage for years (even if it is one of the new models). If your watch is automatic/hand wound, then there might be a problem with movement and in this case you will need help of qualified watchmaker.
8/26/2014 3:42:06 PM • Tissot T Watches • Answered on Aug 26, 2014
Why Touch does not work after battery replacement?
Was the battery empty in the first place, or was the watch already defect? Did you put in the correct and a new battery? or perhaps you did put n the old battery? can you measure the voltage of the batteries, to check? Just a few questions that came up with me.
7/23/2014 11:58:46 AM • Tissot T Watches • Answered on Jul 23, 2014
Just got the battery replaced on my Tissot Supersport Chrono and now the chronograph buttons do not work. Any suggestions before I take it to a authorized repair shop?
Take it back to the shop that changed the battery. They have slightly misaligned the movement to the case. With a watch as good as a Tissot it is better to use a Tissot authorised dealer. My Seiko goes from Canada to London, UK for service.
10/26/2022 10:42:31 PM • Tissot Watches • Answered on Oct 26, 2022
How to set moon phase on tissot pr100
for Tissot PR100 Automatic Chronograph with moonphase, minute recorder, hour recorder and seconds subdials, to set the moonphase there is a sunken button between the chronograph start/stop and the winding crown. Using a pointed object such as a ballpoint pen, push the sunken pusher gently until the moonphase moves one step, (if you press the pusher completely in, it will also advance the calendar hand, so only press enough to move the moonphase and no more for moonphase adjustment)
9/18/2021 6:20:20 AM • Tissot Watches • Answered on Sep 18, 2021
2answers
Hi, I have tissot expert, when I changed the battery, all option work perfect but the screen to activate compass not working and the bip as well,maybe battery not suit the watch ?
It could be that you have purchased the wrong battery for your watch and you should take it to a person that repairs watches and jewelry then to figure out what type of battery that will work in your watch.
3/8/2021 11:53:37 PM • Tissot Watches • Answered on Mar 08, 2021
How to zero the dials on Tissot 1853 watch
The reset button may be defective
11/16/2020 8:15:42 PM • Tissot Watches • Answered on Nov 16, 2020
My Tissot 1853 suddenly started to quickly run forward for 4 seconds and then rest for four seconds, doing that constantly. Is there a fix for this?
Hi. Can I assume this is a quartz powered watch? If so, sometimes, if thger bettery is either old or has started leaking hen is causes misfires in the time regulator.. First step would be chasnge battery & resdet the watch & monitor it. If this does not work, then put it into a Tissot service centre. Ifts not a quartz movement, there is no fault in a mechanical movement really that could cause this. Hope this helps.
10/6/2019 3:28:08 PM • Tissot Watches • Answered on Oct 06, 2019
Tissot Prs516 T91141731 Watch Logo
15 questions posted
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
View Most Popular
T Tissot
  • T Tissot
Most Popular Question
tissot prs516 amp runs fast 1 minute
  • Watches
