20 Most Recent
Tissot T Race T90444631 Watch Questions & Answers
Hi I have a Tissot
I agree with the repair service, in that it probably is not a big deal, but since it is still under warranty, I would contact Tissot at the following to get their professional advice on their product.
http://www.tissot.ch/?mod_contact
Best wishes.
Changed the time and the second hand just stopped.
I suspect that it is in one of the mode settings and is waiting for you to do something.
If you do not have any instructions, you can get them from their web site, so you can check what you did to set the time was correct.
Go to their web site (tissot.com).
At
the bottom of the page there is a menu; select "warranty" and a number
of alternative PDF files appear on the left.
If you can't see
what you want, select "user manual" from the menu at the top and enter
the details of your watch.
Choose the one that is suitable for
your watch and download
Wot size battery do I need for a t472 tissot trace
I think that's a SR936Sw or equivalent. That watch has a pop-off back, so its easy enough to access. You'll need a jewelers pincers or something like a sharp pin to extract the battery (Carefully!) as its embedded in the body.
Why Touch does not work after battery replacement?
Was the battery empty in the first place, or was the watch already defect?
Did you put in the correct and a new battery? or perhaps you did put n the old battery?
can you measure the voltage of the batteries, to check?
Just a few questions that came up with me.
How to set moon phase on tissot pr100
for Tissot PR100 Automatic Chronograph with moonphase, minute recorder, hour recorder and seconds subdials, to set the moonphase
there is a sunken button between the chronograph start/stop and the winding crown.
Using a pointed object such as a ballpoint pen, push the sunken pusher gently until the moonphase moves one step, (if you press the pusher completely in, it will also advance the calendar hand, so only press enough to move the moonphase and no more for moonphase adjustment)
