20 Most Recent Maytag MLE24PDAYW Dryer Commercial Dryer - Stack, Electric, Microprocessor Controls" Questions & Answers
i don't know. most dryers come with a chart showing what wires are for. green is usually used for ground but read
your chart. few have chart with owner's manual and most i have seen are in a clear plastic bag stuck on the back or
stuck in the open area under the tub.
Maytag Dryers | Answered on Jan 07, 2020
Nothing happens when push start button.
All limits are good.
Element tests at .001 ohms.
Maytag Dryers | Answered on Jan 01, 2020
Go to www.repairclinic.com and enter medb835dw4. With luck, you will be presented with a list of replacement parts/assemblies and may be able to view a generic Maytag video showing disassembly.
Maytag Dryers | Answered on Dec 23, 2019
check the drum support rollers
Maytag Dryers | Answered on Nov 23, 2019
I don't know what it means but you can try to reset the control panel by unplugging it for 10 minutes then plugging it back in. This may or may not help but it works every time my dryer gets stuck on or off with the panel display showing something odd, or stuck on so many minutes left but it doesn't ever stop. It won't cost you anything to try this. If it happens very often you may need the panel replaced.
Maytag Dryers | Answered on Oct 27, 2019
I'm having trouble finding the exact capacity of your dryer, but I believe it is around 7.0 cu ft, which is about as large as you can get in a standard-width home dryer.
Maytag Dryers | Answered on Oct 14, 2019
Most likely cause is a thermal fuse or the heating element. And if it's a thermal fuse, you need to make sure the dryer vent is clear and un-restricted, since that is the most common cause of thermal fuses blowing.
Maytag Dryers | Answered on Oct 05, 2019
be very careful with electricity. fuses are in the home's wiring. open the dryer door. if possible follow the wire
from the large plug back to the home's main electrical panel. there may be a small panel just for the dryer or it may be connected directly into the main panel. locate the fuses if used, unscrew them and replace them with ones you know are good or use an electrical meter to test the original fuses for continuity. install good fuses.
if your system uses circuit breakers, locate the breakers and look to see if they have been moved from the on position. switch them off and on a few times and leave them on. go and close the dryer door and choose a new dryer setting to try to see if your dryer works. great if all works as it should. if dryer won't start or fails again, you need to have your house wiring inspected or your dryer repaired. call for help without delay.
Maytag Dryers | Answered on Oct 02, 2019
i don't know. consider shutting off dryer, open the dryer door, turn off the main electrical source [shut off circuit breakers for dryer or unscrew fuses.
shut the dryer door and turn breakers on and or fuses in. this may reset your machine's internal program.
choose a new timed setting to see if all is OK.
It may seem crazy, but you have to remove the dryer door, and then take the door apart to be able to replace the handle! I've tried doing it without taking the door apart, and I only ended up damaging the door and replacement handle!
Maytag Dryers | Answered on Sep 02, 2019
I did A & B, B actually did the trick and I have had absolutely no problems.
Possible Solutions
A
Power unit down by turning off the circuit breaker(s) for one (1) minute.
  1. Power unit up by turning on the circuit breaker(s).
  2. Start a time dry cycle.
  3. Monitor the dryer for one (1) minute to ensure the error code does not display again.
B
It indicates that the lint screen or vent is clogged; the vent is crushed, kinked or has too many turns. ... The dryer will continue to run when this diagnostic code is present.
My dryer did the same thing. I cleaned all the vents thoroughly, if you are unable to clean inside where the vent screen is try this. remove lint screen, using tape or rubberband attach a empty paper towel roll to the end of your vacuum crevice tool. Also at the 99 cent store I purchased a appliance brush to loosen any lint inside before vacuuming. The brush works better then the one I purchased from Home Depot for $15.
Vacuum the inside of the dryer, be sure to vacuum the very back inside and around the door.
This is the tricky part now.
The dryer flex hose actually has to be set just right. If the placement is incorrect you will get the error codes, dryer turns off after mins etc.
Here is a Flex hose tip video. Hope this is helpful
Maytag Dryers | Answered on Aug 24, 2019
if you are turning it from the inside of the dryer with ease then check to see if belt broke.
Maytag Dryers | Answered on Aug 18, 2019
Maytag MLE24PDAYW Dryer Commercial Dryer - Stack, Electric, Microprocessor Controls" Logo
0 questions posted
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
no power maytag neptune dryer change
  • Dryers
