20 Most Recent
Kenneth Cole KC1289 Watch for Men Questions & Answers
I can't seem to find the proper way to change the ...
mcdevito 75 here, Most likely there are 2 positions in the stem (crown assembly) pull the stem out very carefully to it"s first position this should allow you to change the DATE either turning the crown toward you or away from you, once you get to the proper DATE, pull the stem out to it:s 2nd position, spin the hands until you get the proper day. Regards, Mike D 75
How to set time of the Kenneth Cole reaction watch RK5072
They all set pretty much the same. Here is the general walk through from the Cole site:
Press the lower left button on the Kenneth Cole digital watches to cycle through the various modes. Press it three times to get into time mode (the face should be blinking). Press the upper right-hand button to change the seconds. Press the lower right-hand button to select the minutes.
WHAT IS THE BATTERY SIZE FOR A KENNETH COLE KC50477003WATCH?
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by ADMIN... on Dec 31, 2018
How use kenneth cole kc 9110
Instruction Video on How to Size Your Ceramics Watch Kenneth Cole Touch Activated Kenneth Cole New York (US) Kenneth Cole New York (Int'l English) Kenneth Cole New York French (FR) Kenneth Cole New York German (DE) Kenneth Cole New York Italian (IT) Kenneth Cole New York Japanese (JP) Kenneth Cole New York Spanish (ES) Kenneth Cole New York (Simplified Chinese) Kenneth Cole New York (4-Eye Chronograph Movement) Kenneth Cole Analog-Digital Touch Screen Instruction Manual - Korean (KR) Kenneth Cole Reaction unlisted: Analog-Digital: UL1052, UL1069, UL1102, UL1103, UL1171 (EN) unlisted: Analog-Digital: UL1002, UL1070, UL1095, UL1097, UL1099 (EN)unlisted: Digital Instructions (EN) unlisted: UL1154, UL1155, UL1156 (EN)unlisted: Instruction Manual.
Ul 1008 analog portion does not work
Are the hands moving but out of step with the digital display?
If so then try pressing the "mode" button to reach a mode that allows you to set the hands (on my Casio it is "HS"), I would expect something similar on yours.
You can then alter the hands by pressing one of the other buttons. I would expect one button to advance the hands and another to ****** them.
Happy experimenting!
How to get moisture out of a watch
Ive heard people say many times to put cell phones in a bowl of dry white rice to remove moisture from them,so Im sure it would work for a watch as well. Just make sure to leave the watch in the rice over night,and make sure to have none of the watch showing in the rice---it will need to pull moisture from within the tiny parts.
