20 Most Recent Sony Cyber-shot DSC-H10/B Digital Camera Questions & Answers
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances: When shooting MPEG movies When shooting in the Twilight or Handheld Twilight mode If shooting with the Burst or Multi Burst mode Shooting with Sweep Panorama Shooting with the Fireworks or High Sensitivity mode. If an external flash is connected. Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
If the issue persists, please reset the Camera and make sure that battery is fully charged. If the issue persists after performing all the above mentioned troubleshooting steps, service is required. If you feel that the above Troubleshooting steps, helped you. please rate my answer positively. Thanks for understanding.
Sony Cyber-shot... | Answered on Aug 28, 2017
it has to be turned on and opened(lifted) to work .
Sony Cyber-shot... | Answered on Jan 17, 2015
As long as the power cable is in the camera, you can't switch it on. You could try another battery, or chaco if all contacts are clean and shiny. Don't forget to close the battery cover correct. As long as the cover is not closed correct, the camera can't power on. If the contacts are dirty or oxidised, only clean with a dry cloth or cotton swabs.
Sony Cyber-shot... | Answered on Jul 05, 2014
my camera error display e61
Sony Cyber-shot... | Answered on Aug 17, 2013
What a coincidence. Even my camera is 14 months old & I too have exactly similar problem.
Can some one throw some light on this pls??
Sony Cyber-shot... | Answered on Aug 09, 2013
Press left on the control button (marked with a flower icon) repeatedly to select the desired macro mode. See page 26 of the Cyber-shot handbook available from here.
Sony Cyber-shot... | Answered on Feb 07, 2013
lens element got hit one side
Sony Cyber-shot... | Answered on Jan 11, 2013
you have a bad capacitor and will not hold a charge to make a flash burst... you need to send it to sony
Sony Cyber-shot... | Answered on Nov 15, 2012
Check burned bulb.
Sony Cyber-shot... | Answered on Aug 13, 2012
Press cursor-right (marked with a lightning bolt) then select the lightning bolt icon.
Sony Cyber-shot... | Answered on May 15, 2012
The closest thing to a reset is the "Initialize" command in the menu under "Settings" / "Main Settings" / "Main Settings 1".
Sony Cyber-shot... | Answered on Feb 01, 2012
You must send the camera in for repair to replace the flashing unit
Sony Cyber-shot... | Answered on Jan 23, 2012
Your camera should be supported by default without adding any drivers. All you need is a program that will retrieve the photos for you from your camera.
I suggest that you download and install Picasa and use that to manage your photos and retrieve them from your camera:
https://www.google.com/picasa/
Sony Cyber-shot... | Answered on Nov 27, 2011
Hi
This happens when the flash bulb is fused/burnt .Get the flash bulb replaced and will go fine.
Regards.
PLZ> don't forget to rate my suggestion.
Sony Cyber-shot... | Answered on Sep 18, 2011
Sony Cyber-shot DSC-H10/B Digital Camera Logo
61 questions posted
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
suresh Kulkarni
suresh Kulkarni
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
reset macro dsc h 10
  • Cameras
