20 Most Recent
Bell Sports Doubel Back 2 Bike Rack Questions & Answers
Cant install bell double bike rack on my chevy
Why?
I contacted Bell Sports and complained about the lack of downloadable manuals. They said they are in the process of developing the website which will provide them.
http://www.bellbikestuff.com/
It has some basic stuff about helmets and tire changing right now. Stay tuned and check it once in a while.
In the meantime, they sent me the manual for the Doubleback/Tripleback Car Rack in English since that was the one I used as an example.
If you post your email to this solution I will be notified and will send it to you.
Best way to install on a hatchback,
The top bar can rest against your back window, the U bar that swivels can go ontop of your bumper, no bumper? then try to attach it so its help by a lot of pressure on the straps!
Bell f20 resetting trip odomoter DST
Did an obsessive search of this problem and found this: "Right Button" . . . click to display the "DST" (distance) than hold the "LEFT Button" for 2 seconds. YEAH!! Reset trip ONLY!! This problem is simply an error in the instruction manual. ~G~
I have a Craftsman 9hp 29inch blade snowblower
Hi timmmarquez, I have the same snowblower. That plug is for a light if you want to install one. Can you smell gas when you try to start it ? If you have spark you can iliminate the kill switch. Make sure you have a clean spark plug to (not a weak spark). Good Luck.
Bell f20 computer - no code for 25'' wheels?
when i first got mine it prompted me to enter the circumference of my tire in millimeters (mine was 2074mm). you can get back to this by holding the bottom button in the center (this button is really two buttons one on the left side the other on the right side; holding the center pushes both these buttons). when it rests you'll see the 4 digit numbers. i think u use the right button to change the number and the left to move to the next. remember the number represents your tires circumference in millimeters. for a quick approx use this calculation (Tire Diameter)X(3.14)X(25.4). So for me it was (26in)X(3.14)X(25.4) = 2074mm
Hi we need a manual
Hi Linda, i have the same 1983 Travelaire motorhome Econoline F-350 26ft and are in search of the Shop/owners manual ... Do you know where to find one ?
I am located in BC Canada
Reg 250-379-2971
[email protected] if you can contact me ?
How can I maintain my pool table at top condition?
In
order to maintain the condition of your table and prolong its lifetime you
should avoid eating above the table, putting drinks of ash trends on the sides
of the table, and generally try not to harm the cloth with the cue. In addition
you can clean and vacuum the table from the outside once a month, this Is what
I'm doing to my table.
What is the price range of a quality foosball table?
Good quality and long-lasting table start at
about $600. In this case, like in many others, the more you pay, the better
quality you will get. Make sure that you're buying a known brand and compare
prices first, before you buy. It is also recommended to read some reviews about
a table or tables that you like.
