20 Most Recent
Frigidaire Professional Series PHS68EJSB Stainless Steel Side by Side Refrigerator Questions & Answers
Leaking water from my refrigerator
Tubing in back of refrigerator leading to the ice tray is jammed with solid ice and whence maker timer calls for water back pressure prevents water from reaching the ice maker tray. Remove the tubing from the back and pull out the plastic tube that feeds the ice maker tray. Put the tube in hot water to melt the the and blow through it to make sure itis clear. When reinserting the plastic tube stick your head inside the freezer door and be sure the end of the tube overlaps the tray. The problem will be solved but the same thing will happen at some later date. I believe I solved this problem too. I got a roll of surgical adhesive bandage that's about a sixteenth inch thick and insulated the tube to prevent it from freezing again. It's been two months since and thank God it worked. The Frigidaire engineers could use this one.
Frigidaire...
Answered
on Mar 06, 2015
Insulation melted top by light
Good Afternoon Friend,
I understand the insulation has melted the insulation, near the top light, of your Frigidaire refrigerator, model# PHS68EJSB. With having the inside of your refrigerator melted, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of the melting was and how to resolve fixing your refrigerator. I hope this is helpful.
-Best Regards-
WP
Frigidaire...
Answered
on Jun 23, 2014
Refrigerator temp is flashing
Good Morning James, thank you for your inquiry!
I understand your Frigidaire refrigerator is flashing. Let's try resetting your refrigerator by either unplugging it or flipping off the breaker for about ten minutes. If the flashing continues, your refrigerator may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Frigidaire...
Answered
on Dec 16, 2013
Change celsius to fahrenheit
Hello deskds - To change Celsius to Fahrenheit for the model number posted above, press and hold the Fresh Food up arrow while at the same time pressing the Freezer up arrow three times in five seconds.
Frigidaire...
Answered
on Mar 19, 2013
