20 Most Recent
Michele Watches 16mm Stainless Steel Watch Band Questions & Answers
How does it get sized?
You can usually have your local watch shop to shorten watchbands but if they cannot do it then you could contact Michele watches.
You could then discuss any problem you have with them.
Insert "www.michele.com/" into your search engine, at the bottom of the page on the left is a "contact us" link. Click on this for info.
Type of battery in Michele deco diamond watch?
395/399 Duracell on Ebay.
I gave up trying to change the battery last time and had a store do it. This time I was determined to do it myself like I do for the dozen or so watches that we have. The Michelle Deco is a bear, as once you take the back off it has a battery restraining bracket that requires a VERY SMALL screw driver and a lot of patience when it is time to re-assemble it. If you are up to trying it yourself you better have great eyesight, steady hands and the right screw drivers (a magnetic one helps get that tiny battery retaining screw back in). It took me almost an hour but I did it. Good luck to you.
