20 Most Recent Magic Chef Chest Freezer MCCF5WBX Questions & Answers
My Magic Chef chest freezer stopped cooling,
Sounds like slow Freon leak. You might get an estimate over the phone before calling a technician, but I would think a 3-year old box is worth repairing. If the estimate is close to the replacement cost, that might not be the case.
2/25/2018 8:53:34 PM • Magic Chef Chest... • Answered on Feb 25, 2018
My Magic Chef 5.5 cubic chest freezer with manual
Feel compressor to see if running and warm. If not, most likely thermostat control is bad. If it is running, determine if it runs continuously or if it's clicking on and off every couple minutes. If clicking on and off, replace overload and relay that plugs into side of compressor. If running continuously, there is probably a freon leak on blockage. Replace freezer in latter scenario
11/5/2017 8:51:04 PM • Magic Chef Chest... • Answered on Nov 05, 2017
How to add 134a to magic chef deep freezer
First your freezer does not use R-134a. That is for auto air conditioners only. It uses R-12. You need refrigeration compound gauges, R-12 refrigerant and a two devices that connects to and punctures the lines and gives you a port to connect the hoses from the refrigeration compound gauges. You must have a refrigeration leak if you need to add refrigerant. The leak needs to be repaired or you will lose the refrigerant in a short time again.
11/8/2015 9:07:45 PM • Magic Chef Chest... • Answered on Nov 08, 2015
2answers
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
1/16/2015 4:32:54 PM • Magic Chef Chest... • Answered on Jan 16, 2015
Chest freezer not working. Light inside chest freezer comes on but green power light doesn't turn on and freezer makes no sound. What could be the problem.
Could be your thermostat is bad and not calling for the compressor to come on. If you are able see if there is power getting to the compressor. If not then back track to where you are loosing power (thermostat) etc.
11/11/2014 5:01:53 PM • Magic Chef Chest... • Answered on Nov 11, 2014
21inchx42inch is how many cubic feet
should be another mesurement
8/31/2014 10:02:56 PM • Magic Chef Chest... • Answered on Aug 31, 2014
WHAT MAYBE WRONG WHEN MY MAGIC CHEF FREEZER STOPS KEEPING COLD?
Motor burnt-out, leakage, failed circuitry or temp-sensor ...
7/17/2014 2:56:22 PM • Magic Chef Chest... • Answered on Jul 17, 2014
0answers
0answers
Magic Chef Chest Freezer MCCF5WBX Logo
89 questions posted
Top Magic Chef Freezers Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
View Most Popular
Magic Chef Freezers
  • Magic Chef Freezers
Most Popular Question
fast freeze light all time right new
  • Freezers
