20 Most Recent
Frigidaire 19.53 cu. ft. Commercial Freezer FCFS201LF Stainless Steel Questions & Answers
Freezer compressor gets hot
Check behind and underneath for dust buildup, sounds like your compressor needs cleaned on the outside, the dust is causing it to overheat and retain condensation, hence the ice buildup. Easy thing to check, good luck.
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Continuously running freezer
Hi, The picture I get shows the temp control in the uppr left hand corner. It should be set to half of whatever is on the dial.
I had about eight different possiblities on model #. Could I get the whole # and look this up again?
Removing the drain cup
most plastic trays will need to bend slightly,
if you find it to difficult to remove
it is best emptied using s sponge and bucket.
it will however empty buy its self with evaportaion
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
