20 Most Recent
La Marzocco GB/5 Series 4 Groups Espresso Machine Questions & Answers
La marzocco gb5 left group is leaking water constant... how to stop
The hissing inside might be a leak from the vent valve or the level probe connections to the boiler. The leak from the middle if it is not the paddle version or group cap version then the plunger in the solenoid needs to be replaced. If it is the group cap version the plunger in the solenoid and or the gasket inside the group cover might need to be replaced. Before you open the group cover make sure you have replacement parts. You will need H1006, L103/A and L103/B and L100H.
Commercial espresso machine
Sounds like the safety thermostats on the machine is tripping because the machine is overheating or the circuit breaker is tripping because machine needs more amperage.
The pressure is more the
Sounds like the the tube that connects to the pressure stat is blocked or the pressure stat is damaged and needs to be replaced.
3 group Linea
First the breaker
Is the machine on a 20Amp or 30Amp circuit. If 20 then change it to a 30 amp circuit. That should provide enough power for the machine. in some units there is a reset button in the broiler chamber.but if its not in your machine.then there is no other reset button.the problem indicates that its fault in the control panel of the machine.either its a power problem or the fault in the control panel.the machine control panel has to be checked and replaced.
check out.keep updated.thanks.
No steam will come out
Make sure you have the control knob turned the whole way to where it needs to be. You should do the steaming before the brewing, so you have enough water to make the steam. If this isn't the issue, run a mix of 1/2 water, 1/2 white vinegar through the machine. Run 2 or 3 more cycles of plain water to rinse the vinegar out. If the unit was clogged, this will melt the residue away.
La Marzocco espresso machine troubleshooting
Where is the steam coming from the small valve on the top or the big tall one? If it is the tall one then the problem is in the block electrical box(pressure stat) on the left above the element, that may be stuck and not telling the machine that it has enough pressure turn off the elements.
Customer service phone number
Hi there!
You can find all details for La Marzocco
Here
There is also an email form for any parts you require and other information there too.
If this works for you. Please spare a moment to rate as Fixya! thanks
De'Longhi PrimaDonna Soul Coffee Maker not making milk foam.
The milk delivery tube is very narrow bore and in my experience you will find the tube is blocked with congealed milk solids even if you clean then regularly. You need an enzyme milk cleaner like Rinza and even with that you need to manually massage the tubes or remove the blockages. The service engineers just replace them.
