20 Most Recent
LG WM0001HTMA Front Load Washer Questions & Answers
Wm0001htma is stuck at 9 minutes on the spin cycle
You could have a bad control panel, but first thing would to do is unplug for several hours, in meantime of being unplugged, press and hold a start button or whatever you use to start the machine. Press and hold this button for 5 full slow seconds. then wait half hour more so all power is drained from memory, plug back in and try again to see if machine has reset itself.
Water pours from drain hose overflow in front of washer
That drain hose in front has a stopper, to prevent discharge. Either it is not there or not tight or something. You can always clog it shut with a round wood bit inserted or something........I don't think it is too difficult.
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
