20 Most Recent Fisher and Paykel WA37T26G Top Load Washer Questions & Answers
blocked or faulty pump
Fisher and... | Answered on Apr 21, 2018
yes or sometimes it is just not sitting in place correctly
top loader ?
if so burnt out pump if gd blown main computer module
to work out the fault code go from right to left far right light is 1 the next is 2 next is 4 then 8, then 16,32,64,128. add up which lights correspond to your machine and then you can google that code and find what your problem is
Fisher and... | Answered on Oct 26, 2017
you drain pump is the problem,replace it as it is shorting out
it will be the pump. just check again where you did last time. there may be something in the hose, coins can get stuck, and lint. check also the pump is not getting very hot.
Fisher and... | Answered on Aug 12, 2014
Does the Machine fill up with water properly sounds to me like the fill sensor is stuffed or an inlet valve issue . Try checking the level of your machine some will stop half way through a load because the machine out of balance switch is stuck on.
Fisher and... | Answered on Jul 12, 2014
This is the user manual.
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/4112_US_Ecosmart_Washer_EN_FR_UG_lo_0109.pdf
Fisher and... | Answered on Jun 06, 2014
check user manual. or go online for customer service. They should have someone that can help.
It sounds like the pump has went bad & also taken out the main board.
Common fault is pump.
Fisher and... | Answered on May 11, 2014
Fisher and Paykel WA37T26G Top Load Washer Logo
116 questions posted
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Washing Machines
Most Popular Question
water leaks from bottom when filling
  • Washing Machines
