20 Most Recent General Electric WCVH6800J Front Load Washer Questions & Answers
2answers
The unit fills with water and then drains
Try to clean the discharge pump filter first (Instructions in the Use/Care manual).
If the drain pump is working, it's most likely related to the pressure switch. Check out this posting:
http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min
8/26/2021 8:26:06 PM • General Electric... • Answered on Aug 26, 2021
GE front load not spinning/draining the water out properly
That could be your trouble the washer has adjustable legs turn legs to adjust level. Also check the belt for worn out.
2/10/2018 3:50:37 PM • General Electric... • Answered on Feb 10, 2018
Have a new ge WCVH6800 front load washer. Power
Hello there and welcome to fixya You may want to try unplugging the machine for a minimum of 2 hours to let the internal cpu to reset itself then plug it back in then press the mode button then try to lock the door and it should be ok after that ok please inform me how this goes there is more we can do for this ok Best regards Michael
8/13/2014 7:46:34 PM • General Electric... • Answered on Aug 13, 2014
Why does myAmana 7300 front load washer door not open?
If the cycle is done, sounds like your door switch could be sticky,. If there is water in it, it will have to pump out the water to a certain level before the door will open, removal of the water would be your issue or the pressure level switch thinks is not drained out, in which would be a pressure switch.
6/18/2014 4:52:15 AM • General Electric... • Answered on Jun 18, 2014
Motor does not turn, but machine does all other functions
check the belt to see if it has snapped or come off, alternatively, if the appliance is between 3-5 years old it might be worth checking the brushes on the motor unfortunately in the UK we do not have this model
4/11/2014 11:43:50 PM • General Electric... • Answered on Apr 11, 2014
0answers
General Electric WCVH6800J gasket broken
not to hard to change first you need to get it out there is a spring holding it grab the bottom side of the gasket and you will feel the spring not to hard to doit take a picture or samething to remember how to put it back in make sure the drane hole goes on the bottom.
1/29/2014 2:13:58 AM • General Electric... • Answered on Jan 29, 2014
General Electric WCVH6800J Front Load Washer Logo
180 questions posted
Top General Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a General Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • General Washing Machines
Most Popular Question
lock displaying symbol
  • Washing Machines
