20 Most Recent Roper RTW4305S Top Load Washer / Dryer Questions & Answers
The washer will fill with water but will not spin
the motor coupler could be the culprit.
There is a full video with detail instructions on how to replace this here
Best of luck
6/2/2011 9:43:41 PM • Roper RTW4305S... • Answered on Jun 02, 2011
Washer walk around during spin cycle but is level
Sorry to say this BUT I yhink that following the guidance notes below should help!
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning but I've not had any feedback of this nature.
Good luck,
John C
2/18/2011 3:44:53 PM • Roper RTW4305S... • Answered on Feb 18, 2011
The washer will not spin out but if i lift the lid
there is switch which senses whether the lid is closed or open. its either sticky or loose on its mounting. Or the portion of the lid which operates this switch is cracked / damaged.
3/19/2010 5:21:44 AM • Roper RTW4305S... • Answered on Mar 19, 2010
I have a Roper washing machine. Is it normal that she keeps the same water to rinse?
No, it should pump out and add fresh water, agitate, spin, add water again, agitate, and then pump out for final spin. Check the pump and filter area for obstructions. Having said that, the logic board should halt everything and error out if there is no pump out. Try disconnecting from the wall socket for 15 minutes, and then plug back in.
12/12/2023 10:11:07 PM • Roper Washing... • Answered on Dec 12, 2023
Roper washer top loader. I have replaced the rods, the washer works fine until final spin, it's like out of balance.
Check the feet, they must all be firmly planted with equal weight and level left to right and front to back. If your Roper washer shakes excessively during the spin cycle, this can be caused by your machine sitting on an uneven surface, worn-out rollers, or damaged feet. To solve this problem, you will need to level the floor where your washer is sitting or replace its wheels if there are any worn-out parts.
Why Does My Roper Washer Shake And How To Fix?
11/14/2023 10:44:23 PM • Roper Washing... • Answered on Nov 14, 2023
2answers
Roper Washer. Why does Roper washer go off balance?
Suspension rod failure or possibly a rod is out of place if the machine was moved.
https://youtu.be/h6wXWmEoVJY?si=Ubs3TurRVjDoJTpT
9/12/2023 7:24:38 PM • Roper Washing... • Answered on Sep 12, 2023
My Roper top loading washing machine goes thru the first wash cycle, empties the water then stops. It does not move on to the rinse cycle.
If your Roper top loading washing machine is stuck on the first wash cycle, you're not alone! It's a common problem that can be caused by a few different things. First, check to make sure the lid is closed properly. If it is, then you may need to check the timer, the water level switch, or the motor. If you're not sure how to do this, it's best to call a professional. Trying to fix it yourself could end up costing you more in the long run. But don't worry, you'll be back to washing your clothes in no time! Just remember, when it comes to washing machines, it's better to be safe than sorry.
4/15/2023 10:40:24 PM • Roper Washing... • Answered on Apr 15, 2023
ROPER WASHER PULLEY SYSTEM WON'T SPIN OR DRAIN
There are a few potential causes for your Roper washer not spinning or draining:
  1. Drive belt: If the drive belt is broken or slipping, it could prevent the tub from spinning. Check the belt for any signs of damage or wear, and make sure it is properly tensioned.
  2. Lid switch: Even though you said the lid switch is ok, it's still worth checking it again as it is responsible for ensuring that the washer will not spin or drain unless the lid is closed.
  3. Motor coupler: The motor coupler connects the motor to the transmission and can wear out over time. If it has failed, the washer won't spin or agitate. Check the coupler for any signs of wear or damage.
  4. Drain pump: A clogged drain pump or pump motor failure can prevent the washer from draining. Check the pump and clean out any debris that may be blocking it.
  5. Control board: The control board could also be a potential culprit, especially if the washer is not completing cycles correctly. Check the board for any signs of damage or malfunction.
  6. Transmission: If none of the above solutions work, there may be an issue with the transmission. This will require a professional repair.
I hope this helps you diagnose and fix the issue with your Roper washer.
2/26/2023 9:36:22 AM • Roper Washing... • Answered on Feb 26, 2023
There are a few things you can try if your Roper washer is not going through the full cycle because it is only filling with a small amount of water:
  • Check the supply of water: Check to see that all of the water supply valves are open and that the hoses are free of kinks and obstructions. The washer may slowly fill due to low water pressure.
  • Check the valve at the inlet: The washer may not properly fill due to a clogged or damaged inlet valve. The valve may need to be replaced in this scenario.
  • Verify the pressure switch by: The pressure switch tells the control board to move the cycle forward by sensing the tub's water level. It's possible that the control board won't be notified to start the next cycle if the pressure switch is broken.
  • Examine the control panel: The control board may be defective and need to be replaced if none of the aforementioned steps resolve the issue.
2/26/2023 4:58:28 AM • Roper Washing... • Answered on Feb 26, 2023
My roper top load machine will not unlock the lid clothes are trapped inside the washer.
did you click the pause/run button? sometimes that will unlock the door. if not then i would unplug the machine ..
12/21/2022 6:19:22 PM • Roper Washing... • Answered on Dec 21, 2022
So my Roper washer model RAS8445KQ0 will not spin and rinse?
Question edited for typos. Sounds as if the switch was wired wrong. https://www.google.com/search?q=Roper+washer+model+RAS8445KQ0+replace+lid+switch ..
11/27/2022 8:43:48 PM • Roper Washing... • Answered on Nov 27, 2022
2answers
My roper top loading machine washes but will not advance to rinse it fills up but drains immediately after.
Hi, Please power cycle your washer (ie unplug power for 2 minutes before powering on again). Then, you can move your dial counterclockwise (or opposite the direction that you currently turn your cycle-setting dial) by 90 degrees. Then, attempt a full cycle again. This should help somewhat reset your cycle functions so that it works properly. Thank you.
11/1/2022 8:11:29 AM • Roper Washing... • Answered on Nov 01, 2022
2answers
Roper rwt4516 makes squealing sound only during agitation
possible loose or bad belt if ok possible cogs under agitator worn
9/30/2022 9:51:16 AM • Roper Washing... • Answered on Sep 30, 2022
Roper top loader drum has fallen 4 inches and makes loud noises during operation
Depending on age, possibly time for a new one. There are fixes in the link. https://www.google.com/search?q=Roper+top+loader+drum+has+dropped+4+inches ..
8/22/2022 11:54:08 PM • Roper Washing... • Answered on Aug 22, 2022
Troubeshooting Roper Washing machine
Humming is normally indicative of a failed Start/Run Capacitor, but the fact you get nothing from it, leads me to believe it is a control board issue as well. Due the cost, call for Service so that you get the correct diagnosis.
8/2/2022 7:12:34 PM • Roper Washing... • Answered on Aug 02, 2022
Roper RTW4305S Top Load Washer / Dryer Logo
18 questions posted
Top Roper Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Roper Washing Machines
Most Popular Question
washer will fill water but will not spin
  • Washing Machines
