20 Most Recent
Carrier 52CQ-312-4 Comfort Series Heat Pump Air Conditioner Questions & Answers
What size capacitor in a Carrier Heat Pump 38yh036300
This is a three ton heatpump must likely it is a 35/5uf capacitor. But if you can read compressor tag it will tell you size it requires and also fan label will do some for it.you will need to ask for a dual capacitor from supply house make sure you pay close attention to hoe wires hook up so you can wire in new on before removing wires make sure you have high voltage turned off to unit.take pic with phone this will help when you rewire
3/11/2015 2:15:32 AM •
Carrier...
Answered
on Mar 11, 2015
WIREIN HEAT PUMP FOR COOLING ONLY
You must wire Orange from heatpump low voltage wire to gether with your yellow s and you must have a common wire usealy common comeing out of heatpump should be black color than what ever color wire you have connected to common at t-stat and airhandler connect that to black wire at heatpump. To make sure blablack I s common follow wire up to board and it will be connected to C terminal now you will have ac all time. If you want heat remve Orange wire from reds at heatpump and you will get heat only.note when doing your wireing make sure high voltage is off to heatpump and airhandler hope this helps
2/27/2015 2:44:24 AM •
Carrier...
Answered
on Feb 27, 2015
Should a heat pump run all the time?
It really depends on the climate and the design. In Michigan where the winters are cold and the humidity high the air cooled heat pumps run constantly, but here in Arizona they cycle on and off like a regular air conditioner. That's the best answer I can give. Hope this helps and good luck.
10/14/2014 7:19:08 AM •
Carrier...
Answered
on Oct 14, 2014
Furnace won't stop running
Jump out limit switch blower should stop and inducer should come on then the heating sequences should start from there
11/29/2013 12:42:27 AM •
Carrier...
Answered
on Nov 29, 2013
Ice on coils of heat pump not cooling
Which coil?, indoor or out? Indoor coils freeze due to clogged filters, low freon, blower motor not working. Outdoor coil freezing could mean, in rare cases in cooling mode, reversing valve not shifting.
10/2/2013 3:14:17 PM •
Carrier...
Answered
on Oct 02, 2013
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
7/1/2012 1:55:36 PM •
Carrier...
Answered
on Jul 01, 2012
Gas emergency heat pump comes on with chemical odor
If the emergency heat doesn't come on very often, it will burn off debris that has collected on the heat exchanger causing the smell. Also, check that there aren't any chemicals that are being stored around the unit that would put out fumes that can be drawn into the system and when heated, cause the odor.
3/31/2009 4:14:42 AM •
Carrier...
Answered
on Mar 31, 2009
E7 problem in carrier ac 5 ton
Zamil 2 ton non inverter split type e7 error what is the problem !? ... There is a mode conflict. Some units are calling for heat and one is calling for cooling.
