20 Most Recent
Frigidaire FTF2140F Front Load Washer Questions & Answers
Frigidaire washer ftf2140fs2 lights on the right side keep beeping washer wont start
Hello 2cats - First, is the drain pump making a humming noise? If so, the unit could possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Other possibilities could be a faulty door lock, timer, pump, or control board not communicating correctly. In this case I would contact a professional to move forward accurately to properly diagnose and repair the washer.
Frigidaire frontload FTF2140ES3 33 month old,
If the bearing is bad it will likely do one of three things, it can sound like a jet is taking off when your washer is spinning, the rear bearing seal can start leaking, or if it is really bad there will be slop between the basket and tub. Open the door and spin the basket, does it sound like the bearing has gravel in it? Lift on the basket if it has slop between the basket and tub this will for sure cause the banging you are talking about. To verify the leak you will have to pull the rear cover off of the machine and look for grease or water trails running down the rear of the tub. Often times the grease or water will get on the pulley or belt and fling it around the rear of the washer. Hope this helps.
MODEL WASHER # FTF214OFS2 BLINKING AND BEEPING LIGHTS WONT STOP
Hello Jennifer Brookman - Unfortunately from what you are describing it sounds like the washer is either experiencing a communication error from the control board or wiring failure. Since you have already tried the basic troubleshooting by flipping the household circuit breaker off, do you notice if the door is securely latching? If it is not, then the issue can also lie with a faulty door latch assembly. I suggest contacting a professional for a proper diagnosis and to move forward accurately.
The washer agitates, but then
The washer will not spin if it cannot drain the water. There is a filter in the hose from the tub that leads to the pump. You can access it from the front by removing the front lower panerl. Remove the large, black rubber hose on the bottom of the tub and the filter will pull out. Water will come out, so be prepared!
Kelly
It shakes so violently, it knocked 2 holes in the
take bottom panel off,check the shocks,if it is making loud noise it's probably spider gear,if you keep using it the boot could rip off and you'll have a flood,get rid of washer it will cost as much to fix washer that you could buy a new one but that's up to you to decide
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you!
I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
