20 Most Recent Asko WL6511W Front Load Washer Questions & Answers
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Asko WL6511W... | Answered on Jun 16, 2010
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Asko WL6511W... | Answered on May 21, 2010
It's the pump motor -Plug your machine and run a test cycle and check for some grinding noise. Pulled the pump out from under the washer instead of taking the whole thing apart much, much easier.
Asko WL6511W... | Answered on Apr 10, 2010
we have a little trick here to do take the waste pipe and lay it flat on the floor and let all the water out then try the door if not unplug it and take the top off shine a light down and find the switch and put your hand down and pull the leaver
Asko WL6511W... | Answered on Dec 07, 2009
Purchased ASKO Washer WL6511XXLP and Gas Dryer with pedestals, 12/01/09. It threw a drum paddle during 2nd. wash cycle. Damaged several articles of clothing.
ASKO replaced the paddle 2/19/09 after a lot of phone calls (lip service from the ASKO 800 #). They claimed the part had to come from Sweden (reason for delay).
Washer threw another drum paddle during 4th. wash cycle. Damaged several more articles of clothing. We have made no claim for the damaged clothing, the retailer has been cooperative.
ASKO has promised to replace the washer after the retailer we purchased the washer from, strongly encouraged them to do so. We are still without a washer (03/23/09). My wife and I are retired, I am 76. Point being; we do not abuse washing machines and we don't like going to a launder-mat.
I know this is not the venue to address this problem, but am at my wits end.
Asko WL6511W... | Answered on Mar 23, 2009
https://www.repairclinic.com
Asko Washing... | Answered on Dec 08, 2019
The drawer is flushed at some point in the wash cycle to remove powdered detergent residue.
Asko Washing... | Answered on Nov 27, 2019
Apparently it is as much as a 16 year old model, and I could not locate instructions for that model, using https www.google.com.
There was a site with parts, however, but not a manual.
A similar model manual, for W6021, shows controls that may be similar.
https://www.manualslib.com/manual/396407/Asko-W6021.html
Asko Washing... | Answered on Oct 12, 2019
It is likely that the timer is stuck and will have to be replaced.
Asko Washing... | Answered on Sep 18, 2019
Asko WL6511W Front Load Washer Logo
35 questions posted
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
ROB
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Asko Washing Machines
Most Popular Question
anyone know obtain service manual
  • Washing Machines
