20 Most Recent Fisher and Paykel WL37T26D Top Load Washer Questions & Answers
I would call the local engineer for a quote as you would need the repair manual to find the fault if you are able to read the diagram eric
Fisher and... | Answered on Jan 20, 2018
Timer "hangs up" at the start or lid switch is defective.
Fisher and... | Answered on Jul 03, 2017
How high does the drain hose go? If there is too much rise in the hose to the drain then it is building too much pressue when trying to drain.
Fisher and... | Answered on Oct 29, 2013
Remove the small whit plugs and screws at the fron, you will see them when you remove the lid. Lift up top panel and you will see them there.
Fisher and... | Answered on Aug 08, 2012
Hi - with aquasmarts there is a plastic dome like fitting in the middle of the agitator & unscrew this to remove the unit.
Fisher and... | Answered on Jan 06, 2012
The washer filling so slowly can get very irritating and frustrating..most of the time the fix is very simple. The hoses have a screen in them to catch any dirt that may come in the water and this screen plugs up.
Simply unhook the hoses at the washer and clean the screens.
This tip will explain this in more detail for you..
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
Fisher and... | Answered on May 05, 2010
This is error code 40.
40. (00101000) Basket Dis-engage Fault
While carrying out a basket check, the Motor Control Module has found that the basket is
not engaged even though the pressure sensor indicates that the basket is empty. The
Motor Control Module continues to check for 2 minutes, after which time it displays this
fault. The first two areas to check are the clutch and the pressure tube. If these two
appear correct, then the fault could be in the pressure sensor in the Motor Control Module.
Primary Source: Mechanical.
Action: 1) Check that there are no clothes or other foreign objects preventing
the clutch from re-engaging. Excessive suds can stop the basket
rotating.
2) If the machine is empty of water, carry out a clutch disassembly
procedure and check the spline drive.
3) Next check that the pressure tube has not come off and that it is
not kinked.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Fisher and... | Answered on Nov 18, 2019
What appliance is it?
Fisher and... | Answered on Nov 14, 2019
Fisher and Paykel WL37T26D Top Load Washer Logo
22 questions posted
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Washing Machines
Most Popular Question
tring 2 install straps 420978p
  • Washing Machines
