20 Most Recent Hotpoint VBSR3100GWW Top Load Washer Questions & Answers
REPLACE WATERVALVE
Hotpoint... | Answered on Jun 17, 2012
Make sure you are not over filling the washer, when my mother in-law does the laundry, it ends in a tangled mess. However when I wash them, no problem I shake the clothes out before I put them in and I try not to overload the washer.
Hotpoint... | Answered on Feb 27, 2011
pin? there is none
Hotpoint... | Answered on Jun 23, 2010
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. There is a video at http://appliancehelponline.com/toppressureswitchvideo.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Hotpoint... | Answered on Jun 04, 2010
Check the belt and motor brushes. Belt may have come off or snapped and if motor brushes are getting worn they may not be making enough contact in the motor to make it agitate.
Hotpoint... | Answered on Feb 17, 2010
Does it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it using the lid itself . Occasionally , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down . Have to replace the lid switch for it to work properly or bypass the lid switch from under the console .
Hotpoint... | Answered on Aug 18, 2009
hi there.sounds as if your cold water inlet valve needs replaced....
regards Sir Galahad
This washer uses a electric pump. Strings and coins can easily stop the small inpeller. The pump comes apart for cleang. You must remove the front panel by inserting a putty knife in the tp and using downward force the front will come off.
Pull the panel towards you and simplely lift it off the bottom mount. You can now inspect that pump. Lower the drain ose into a bucket to allow as much gravity flowing water to get out before you remove the pump housing. Just unlock the tab and twist apart the pump to get the strings and such out. Have rags ready. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hotpoint... | Answered on Jul 17, 2009
Simply pull up very hard it will come loose. You might want to try and old leather belt or strap under the agitator and pull up.
Hotpoint... | Answered on Jul 12, 2009
Very likely your drain hose is set too low. You can solve this with a standpipe or a kit called a siphon break.
Hotpoint... | Answered on Dec 31, 2008
ABOUT HALF FULL IS ALL YOU WANT SO LOAD IS NOT IMPORTANT OVER FILLING JUST WASTES YOUR TIME AND MONEY
Hotpoint Washing... | Answered on Jan 14, 2020
f-05 usually relates to either the pump being blocked or the sump of this particular model being full of coins, color catchers etc.
first keep it simple, ensure outlet hose is not blocked or kinked....but if not follow these steps
  • To sort this isolate from mains
  • take off back inspection panel.
  • tilt machine forward- get sum1 to hold it for u.
  • The sump is the black hose attached to drum.
  • place a basin under this and loosen jublie clamp using star head screw driver/ 8mm socket,
  • pull sump downwards and remove any blockage.
  • note the plastic ball is part of the sump assembley.
  • refitt the sump again and tighten clamp, pull down firmly on sump to ensure fitted correctly
if there was nothing in the sump it is sumthing jamming the pump, hairgrip, nail, etc.
tilt machine forward as above with a basin ensuring isolated from mains power
  • pump is attached to other end of sump hose, right side of machine as you look in the back.
  • using flat screwdriver lift plastic tag up and slide pump assembley to the left releasing it from base of machine
  • clip of plastic cover from top of pump
  • remove wires from pump
  • u should now be able to turn pump around so u can see 3 hex head screws
  • remove screws taking note of the position of pump
  • remove pump and clear blockage
  • reverse steps to reassemble
if this does not sort it poss a new pump needed
Hotpoint Washing... | Answered on Jan 05, 2020
Hotpoint VBSR3100GWW Top Load Washer Logo
Popular Tags
27 questions posted
Top Hotpoint Washing Machines Experts
Eric Taylor
Richard C Cohen
Richard C Cohen
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
hotpoint washer will not agitate
  • Washing Machines
