20 Most Recent General Electric WHRE5550H Top Load Washer Questions & Answers
General Electric Washer Model# whre5550h1ww makes a clacking sound in wash cycle about i se
There is a known problem with this GE model. Remove the front panel, look at the base plate below the motor. Can you see that it has been rubbing there? On that model the "front apron bracket" fails allowing the motor to rub againist the base. You will need to replace the apron with the new design they have out.Here is the part to order.You may also check this by removing the front and run a load of wash and watch the motor.Please post back your finding to me.
11/6/2013 12:32:18 PM • General Electric... • Answered on Nov 06, 2013
General electric washer makes clacking soun in wash cycle every time it cycles.
There is a known problem with this GE model. Remove the front panel, look at the base plate below the motor. Can you see that it has been rubbing there? On that model the "front apron bracket" fails allowing the motor to rub againist the base. You will need to replace the apron with the new design they have out. Here is the part to order.You may also check this by removing the front and run a load of wash and watch the motor.Please post back your findings.
11/2/2012 6:49:03 PM • General Electric... • Answered on Nov 02, 2012
2answers
Leaking water from the bottom all over the floor,
check the pump or drain pipe,these are the usual suspects
11/4/2010 5:16:59 PM • General Electric... • Answered on Nov 04, 2010
How do i drain the water from the pump of my
The pump will actually withstand the freezing, but to play it safe, just lay the drain hose down flat on the floor and allow the water to run out.
8/21/2010 6:15:08 PM • General Electric... • Answered on Aug 21, 2010
Water leak at hose connection end at machine
hello it is a simple repair , you either need to tighten the hose connection or replace the hose , you can buy them from bunnings store, if the hose is old better replace it
7/23/2010 1:06:41 PM • General Electric... • Answered on Jul 23, 2010
2answers
Purchased a GE washer WHRE5550kww need to know why
Hello....I don't know the answer to your question, but would like to know if you like this machine in general, are you happy you bought it??? Would you buy it again? Thanks
11/26/2009 8:41:36 AM • General Electric... • Answered on Nov 26, 2009
How do I fix E53 code on Super General washing machine please?
Ideas in the link, but this is a commercial washing machine. https://www.google.com/search?q=super+general+washing+machine+E53+code ..
4/7/2024 6:03:32 AM • General Washing... • Answered on Apr 07, 2024
Super General Washing Machine SGW10225. It's not drying, when it come to the dry point it go back to rinse step and start rinsing again. It's a new machine, just bought.
We don't have these strange machines in north America. If it is new it is under warranty and needs a claim. It sounds like the main board has failed, or the timer. Not finding that model https://www.google.com/search?q=Super+General+Washing+Machine+SGW10225 ..
3/13/2024 2:25:09 AM • General Washing... • Answered on Mar 13, 2024
Super General Washing Machine. E3 and F8 which error on the washing machine?
Question edited for clarity. E3 is a generic 'Off Balance' code If you receive an E3 Error code, your washer may be unbalanced. This could be caused by the washer being too tightly packed, or clothing not distributed evenly. This will usually occur during the spin cycle. Stop the spin cycle.
E3 - Error Code - Stacked Laundry Center - Whirlpool Canada
F8 is taking too long to fill. Check the filter screens on the rear hoses. The F8 E1 or Lo FL error code means your washer is not detecting the correct amount of incoming water. If the washer has an F8 E1 error or LO FL error, the door may be locked, and the control may be unresponsive. Aug 21, 2023
F8 E1 or LF or LO FL Error Code in Display - Washers - Amana
9/24/2023 1:18:04 AM • General Washing... • Answered on Sep 24, 2023
2answers
I have a super general washing machine that i bought online.. I've tried to use it but the water is always coming out to the hose..
did you get the 4 rubber washers that go in the hose ends?
3/5/2023 5:49:11 AM • General Washing... • Answered on Mar 05, 2023
Super general washing machine continue pump running and show e12
The error code E12 on a Super General washing machine indicates a drainage issue. This could be caused by a few different things:
  1. Clogged drain hose: The drain hose that carries the water from the washing machine to the drain may be clogged. Check the drain hose to make sure that it is not blocked by debris.
  2. Drain pump: The drain pump is responsible for pumping the water out of the washing machine. If the pump is clogged or damaged, it will not be able to pump the water out and the machine will display an E12 error.
  3. Drain filter: The drain filter is located in the drain pump and is responsible for trapping debris that may clog the drain hose. Check the drain filter to make sure it's not clogged.
  4. Control board: The control board manages the washing machine's functions and if it's faulty it can cause the drain pump to run continuously and display the E12 error.
It's recommended to first check the drain hose, drain pump, and drain filter to see if they are the cause of the issue. If these are all clear, the problem may be with the control board, which will require professional repair. Please be careful when checking the drain pump and filter, as the water may be hot if the machine is in the middle of a cycle.
1/23/2023 3:27:24 PM • General Washing... • Answered on Jan 23, 2023
My super general top load automatic washing machine model sgw720n water level won't stop and over flow!
If the water level in your Super General SGW720N top load automatic washing machine is not stopping and is overflowing, there could be a few possible causes. Here are a few steps you can try to troubleshoot and fix the problem:
  1. Check the water supply hoses: Make sure the water supply hoses are properly connected and there are no visible signs of damage or leaks.
  2. Check the water level sensor: The water level sensor is responsible for controlling the water level in the machine. If it is not functioning correctly, it could cause the water level to continue rising. You may need to have the sensor cleaned or replaced by a professional.
  3. Check the water inlet valve: The water inlet valve controls the flow of water into the machine. If it is not functioning properly, it could cause the water level to continue rising. You may need to have the valve cleaned or replaced by a professional.
  4. Check the control board: If the problem is not with the water supply hoses, water level sensor, or water inlet valve, it is possible that there is an issue with the control board. You may need to have the control board inspected or replaced by a professional.
If you are unable to resolve the problem on your own, it is recommended to contact a qualified service technician or the manufacturer for further assistance. It is important to follow the manufacturer's instructions when attempting to repair or troubleshoot your washing machine to avoid causing further damage or injury.
12/31/2022 9:33:37 AM • General Washing... • Answered on Dec 31, 2022
Super General 7 kg fully automatic Top-Loading Washing Machine SGW-721. It has E error on it.
Question edited for a bit of clarity. This doesn't appear to be a General Electric (GE) machine and looks to be an Arabian machine. We are in North America. This link might work better for you in your county. https://www.google.com/search?q=super+general+automatic+washing+sgw721+e+error+code ..
11/22/2022 6:02:34 PM • General Washing... • Answered on Nov 22, 2022
I have super general washing machine 7kg top load showing error code e3
e3 mean to much water in washer,check inlet valve, are call a techicain to solve your problem
7/15/2021 11:59:21 AM • General Washing... • Answered on Jul 15, 2021
Error 4 in super general SGW 620 top load washing machine..how to solve ?
It has a blocked sensor pipe. Clean and service the machine.
3/11/2021 4:14:59 PM • General Washing... • Answered on Mar 11, 2021
How can i fix F8 error in automatic washing machine? Super general sgw721 top load
Too much water in the machine. Check the drain pump, outlet pipe and filter if any.
12/4/2020 10:11:45 AM • General Washing... • Answered on Dec 04, 2020
I Have E60 Error on my washing machine Super General SGW-8100, What that means? Somebody mentioned reset button to press for 5 seconds, where to find it??
check out this youtube video on e60 error https://www.youtube.com/watch?v=-6iNKH9qhKU
11/30/2020 9:05:39 AM • General Washing... • Answered on Nov 30, 2020
Super General Washing Machine No Power on LED display? we already check the fuse and replaced
check voltage from switch to power board if ok bad display
10/24/2020 8:19:06 AM • General Washing... • Answered on Oct 24, 2020
General Electric WHRE5550H Top Load Washer Logo
20 questions posted
Top General Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a General Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • General Washing Machines
Most Popular Question
general electric washer model
  • Washing Machines
