20 Most Recent
Juniper Networks J2350-JB-SC Router Questions & Answers
Unblock blocked domains
This question is very broad but if you are finding blocked domains it is usually due to DNS black listing and a proxy server. or just a proxy server. If you have access to the proxy server you can remove the domains from the deny list but if you don't you might be able to contact your IT administrator and request them to be unblocked.
Jukeboxi nsm country
Unless you are very tech savy and know what you are looking at the gripper can not be aligned without speciality tools. You can see if everything seems to be aligning correctly by removing the CD box cover and slip in a CD and watch the spindle and gripper come together but be very careful that you don't get flashed by the laser could cause eye damage. Also being careful when pulling apart and putting back together not to warp anything which could leave the CD play useless.
What do I do with this sticker
I would save it for when you find a spot of rust on your car, or someone scratches it somewhere and you cannot afford to have it repaired. Just whack the sticker on and presto! Problem solved!
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
