Panasonic SC-PT660 Theater System • Uploaded on Dec 08, 2014
Hi
Sounds like the timing for the drawer has been knocked out of alignment.You can take top off to remove the discs...the timing can be realigned( assuming there are no broken parts). The trays can skip gears and sometimes be returned to their alignment but usually the plastic breaks easily and some important tab gets broken off unplug the unit for a minute, that is a "reset" or sometimes there is a tiny hold with a button inside, but its usually got "reset" written somewhere next to it If all else fails, look for the SAMS photofacts or the service manual, one of the authorized service centers will have one. Panasonic makes excellent equipment usually made to be fixed .The best way to re-align the timing is top obtain the service manual. Here, it will give you detailed instructions on what marks to line up....you may be able to get a service manual from UED.net...They are a Panasonic parts dist.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
Check for loose speaker connections as a root cause for intermittent shutdown.
48 questions posted
491 Questions
91 Questions
82 Questions
74 Questions
53 Questions
