20 Most Recent
Samsung HT-AS720ST Theater System Questions & Answers
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
9/27/2013 7:15:26 PM •
Samsung...
Answered
on Sep 27, 2013
We have a samsung AVR
Disconnect all wires to the receiver and speakers and connect them back again. The receiver should be on a surround or 5.1 mode
5/3/2011 1:34:35 AM •
Samsung...
Answered
on May 03, 2011
Hi, I own An HT-AS720ST surround System. I just
Hissing is cused by noise interference which is usually bad cableing or bad reception of the station or device if wireless then check out your hosehold appliances and start shutting them off one at a time and see if that clears it up. Somethng is tagging along for the ride on the same freq or close to the freq if wireless
2/16/2011 6:05:42 AM •
Samsung...
Answered
on Feb 16, 2011
Static coming from the front
I had this same issue about a year after I bought the product. Sent it back under warranty and about a year later, I have the exact same issue again. Never buying samsung receivers again.
12/16/2010 6:57:25 PM •
Samsung...
Answered
on Dec 16, 2010
The front right speaker channel on my Samsung
IF it is out of warranty, you can open it up and look for loose connectors on the boards. It may be a poor connection that is visible. Otherwise it may be a connection problem that is hidden/internal. Bad solder connection on the board/speaker tabs, etc.
10/21/2010 10:16:34 PM •
Samsung...
Answered
on Oct 21, 2010
