20 Most Recent Sony BRAVIA® DAV-HDX277WC Theater System with Wireless Speakers Questions & Answers
setup amp input for analog sound
setup dvd ouptup for standard
Sony BRAVIA®... | Answered on Dec 14, 2015
One of the speaker outputs are burnt,need power board replacment (audio output board, not power supply) don't replace components on board since is very difficult
Sony BRAVIA®... | Answered on Aug 23, 2011
Your only choice is most likely a 3.5mm minijack cable. Take the laptop to a Radishack and make sure that cable will fit. The Sony should have an input for that cable even if it is the headphone jack. If your laptop has other audio outputs like an RCA or hdmi, which is unlikely, you would connect one of those cables between it and the Sony (Sony's input).
Sony BRAVIA®... | Answered on Jun 01, 2011
Verify that all speakers work for test tones first. The center carries most of the dialog. It's in the manual, as is your symptom (page 101).
Sony BRAVIA®... | Answered on May 21, 2011
Why don't you try it without any speakers connected. That would prove if the problem is internal or external. Then either isolate the external speaker path that's causing it or get the unit fixed (internal).
Sony BRAVIA®... | Answered on Jan 16, 2011
Strickly speaking about the audio:
The unit has digital audio in on 1 each coaxial and digital connectors.
Most DVD players have digital audio out in either a coaxial (RCA-looking) cable or optical cable.
Consider this: your TV is not a Source of audio (or even video, if you think about it). You probably get your programming from a cable or satellite box, Its audio should be available digitally.
If your DVD and cable use DIFFERENT types of digital audio sources, you're in luck. Attach each one to its compatible input on the Bravia. If you only have two optical outputs you can only attach one at a time.
If you have only two COAXIAL digital audio sources you CAN combine them into a single digital input on the Bravia by getting an RCA-splitter cable to connect them both to the one connector. It will only work if you leave one source dormant or off at any time you're monitoring the other source, otherwise you'll have two digital 'converstions' going on with the Bravia at the same time and it won't be pretty.
Sony BRAVIA®... | Answered on Dec 14, 2010
Your laptop only has an stereo output so it is not possible. I don't know if there is any gadget that you can connect to the usb, and get a surround output from a computer. You may wana check that out, and if there exist such a device it surely would have a software to go along with it.
Sony BRAVIA®... | Answered on Nov 25, 2009
It sounds like either the input selected to the receiver is wrong, the wires are not hooked up correctly, or the wires are bad. What type of connection are you using-RCA jacks, DVi connector, etc?
Sony BRAVIA®... | Answered on Jul 16, 2009
Hi....I haven't hooked mine to the TV yet.....building my cabinet now....but I did hook up the components to make sure they worked and just didnt include a TV on it. My S-Air wireless linked up the first time I tried it....I will say this though, the little wireless transceivers blocks you have to plug into the DVD player and the S-Air do not go in like you would think. They actually look like they are upside down when you get them in, and the must snap in very securely. Make sure they dont just LOOK like they are plugged in. Also, dont get em to far away through too many walls, Try linking it sitting right close to the DVD. Also remember the S-Air remote has its own volume control as well as other controls....
I know I wasnt much help but I just got mine and I will be back with more after I try the surround sound on the TV.
Sony BRAVIA®... | Answered on May 03, 2009
most all theater systems come with a remote and it,s odd that your,s did not, usually their are certain functions that you can control from the head unit ,but nowadays you can program a universal remote to your brand that will be able to control the functions of your theater system ,but to make things easier, call the customer service dept of sony and tell them your model# and purchase it direct from the manufactuer, this remote will have set-up functions for your dvd menu,s and will be easier then having to get up off the couch to change settings , thank you ,hope this helped glenn
Sony BRAVIA®... | Answered on Mar 03, 2009
Hi have Sony STR-AV 970 not getting any sound from receiver panel lights up, and the FM
Station is up and running but no sound from either A/B speakers as well as the phones
Sony Audio... | Answered on Jan 21, 2020
Sony BRAVIA® DAV-HDX277WC Theater System with Wireless Speakers Logo
30 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
system works great dvd radio ipod
  • Audio Players & Recorders
