20 Most Recent Yamaha Dtxpress Iv Special Electronic Drum Set Questions & Answers
My bass drum pad doesn't work I get a drum
If you have already tried a different cable and it didn't work, then the issue might be with the bass drum pad itself. You can try the following steps to troubleshoot:
  1. Check the connection: Make sure that the cable is firmly plugged into both the bass drum pad and the module. If the connection is loose, the signal may not be transmitted properly.
  2. Check the sensitivity setting: Check the sensitivity settings on the module for the bass drum pad. It is possible that the sensitivity is set too low, and the pad is not registering hits.
  3. Check the pad: Check the bass drum pad for any visible damage or wear. It is possible that the trigger inside the pad is damaged or malfunctioning.
  4. Reset the module: Try resetting the module to its default settings. Sometimes, this can fix issues with individual pads.
If none of these steps work, it may be necessary to open up the pad and check the trigger mechanism inside. If you are not comfortable doing this yourself, you can take it to a repair technician.
4/10/2023 12:55:57 PM • Yamaha Dtxpress... • Answered on Apr 10, 2023
3answers
I've got this Machine Yamaha DTxpress Special
Have a look at the update at their site and see if it helps:http://www.xlnaudio.com/?page=downloads
8/6/2022 9:35:14 AM • Yamaha Dtxpress... • Answered on Aug 06, 2022
2answers
Have problem with foot switch on Yamaha extreme 2s drum module
Hi Rafael, comment what is the problem, no action, do not change, you have tried with another foot switch I suggest you clean the connection jack of the foot switch, applying a small amount of clean contacts, check that the cable is not cut Test, being connected, press the cable, on the output of the plug connector, to see if it will work, if so, you have the cable cut to the outlet of the plug, simply replace it and test I hope you serve my comments and you can solve the problem Greetings Franco Dosil Hola Rafael, comenta cual es el problema, no accion, no cambia, has provado con otro interruptor de pie te sugiero que limpies el jack de conexion del interruptor de pie, aplicando una peque?a cantidad de limpia contactos, controla que el cable no se encuentre cortado Prueba, estando conectado, presionar el cable , en la salida del conector plug, a ver si llega a funcionar, de ser que si, tienes el cable cortado a la salida del plug, simplemente reemplazalo y prueba Espero te sirvan mis comentarios y puedas resolver el problema Saludos Franco Dosil https://data2.manualslib.com/pdf2/35/3412/341153-yamaha/dtxtreme_iis.pdf?37d6043730ba4bedfc5430a12894fd26&take=binary
5/15/2019 1:31:39 PM • Yamaha Dtxpress... • Answered on May 15, 2019
7answers
DTXPlorer
You can replace the battery yourself in about 20 minutes. It is not soldered. You will need a replacement battery, which is a CR2032 watch battery, a small Philips screwdriver, and needle or thin-nosed pliers.
1. Remove all cables from the dtxplorer unit, and remove it from the drum kit rack.
2. Remove all 6 screws from the bottom side (i.e. opposite the face)
3. Remove the 3 lowest screws from the rear (jack-filled) side, including the one which holds in the little plastic power cord hook, then lift off the bottom and set aside.
4. You will see the bottom circuit board, covering the top board. Carefully pull off the spade connectors from the power switch, using pliers or patient wiggling, they are on fairly tight but will come loose. Note which one is which for proper reattachment.
5. Near the center of the board is a little white plastic post end sticking up, through a hole, from the inside (top) board, with small tabs. This loosely attaches the two boards. Using small pliers, squeeze the tabs on the post end, and pull up on the board and it will separate from the inside (top) board. Carefully move the board toward the front of the unit to free the jacks from the holes in the case, and then you can easily fold the board toward the front, like opening a book. (Don't try and remove the large wire sets attaching the two boards)
6. You will see the button-like battery. Just push it toward the spring clips at one side and lift it out. Replace it with the new battery, + side out.
7. Just reverse the steps to reassemble, hook it up and you're ready to go. Easier to do than this makes it seem. Greg
1/4/2019 6:40:16 PM • Yamaha Dtxpress... • Answered on Jan 04, 2019
Hi. I've got a problem with my hit hat controller
Sounds like the internal switch in your pedal. Get an OHM meter, and check the continuity when you press and release pedal. Should change from Open to Short. If not, take it to a Tech.
10/15/2018 2:24:04 PM • Yamaha Dtxpress... • Answered on Oct 15, 2018
Dtxpress ii
Open pedal, check with Ohm Meter when you open/close it at the connector. Fix.
12/14/2017 1:04:44 AM • Yamaha Dtxpress... • Answered on Dec 14, 2017
0answers
CHANGE THE SENSITIVITY OF DRUM PADS ON (YAMAHA DTXPRESS IV SPECI)
http://www.yamaha.co.jp/manual/english/result.php?div_code=emi
This should link to owners manual..Hope this helps.
3/31/2015 5:06:04 PM • Yamaha Dtxpress... • Answered on Mar 31, 2015
Snare stops working after 3 or 4 min. to fix I have to switch sets over and over again.
sounds like you have a wire connection problem check your switches make sure they are connected properly.
11/5/2013 7:33:43 PM • Yamaha Dtxpress... • Answered on Nov 05, 2013
Dt express snare sound changes
Check your snare and the red knob next to it, if you turn this knob it will turn off the snare, it could even have a short or etc.
2/7/2013 4:13:52 AM • Yamaha Dtxpress... • Answered on Feb 07, 2013
Hi Hat pedal not fuctioning
Obviously the hi hat trigger does not function properly, it either does not generate enough signal, or the signal doesn't come thru well, or the signal comes thru well but it doesn't trigger the sound unit properly.
This could be caused by:
- too low input sensitivity setting on the sound unit for the hi hat input
- a displaced or loosely fixed sensor (trigger) on the hi hat
- a partially damaged sensor
- a bad wire connection at the sensor
- a bad wire connection at the sensor connector
- a dirty contact on the sensor connector
- a dirty contact on the cable connector at either side of the cable
- a bad cable, a broken wire or poorly soldered wire in the cable connector at either side of the cable
- a dirty contact on the input connector of the sound unit
- a bad solder connection on the input connector of the sound unit (inside the unit)
- a bad solder contact on a component or a faulty component associated to that particular input in the sound unit (capacitors, resistors, diodes, transistors, ICs, etc.)
To rule out a damaged cable, just change it and see if the hi hat works ok with another cable, if it does, the cable was damaged.
If the sensors are interchangeable , try to swap the sensor with a sensor from another cymbal, see if the other sensor works well, if it doesn't, then the sensors are not the problem.
To see if there is a problem with the input on the sound unit, connect another cymbal to that input, if it works well, the input is not the problem, if it still doesn't work, check sensitivity/trigger level setting, check connector contacts for any dirt, check connector and component solder contacts inside the unit.
Also, try to connect the hi hat to another input on the sound unit, if it doesn't work well after that, there's a problem with your hi hat (sensor, wires, dirty connector on the sensor), if it works well instead, then there's a problem with the hi hat input on the sound unit (sensitivity/trigger level, dirty connector contacts, bad solder contacts, damaged components)
Another thing: try your hi hat connected as is, but have someone move the cable connectors while you play it.
If moving the cable connector at the sensor side results in a change of operation (it might start working well for an instant or so), you definitely have a problem with that connection (check for bad wires in sensor connector, cable connector and for dirt on both connectors' pins).
If moving the cable connector at the sound unit input side results in a change of operation, then there's a problem with that connection (check for bad solder points on the input connector inside the sound unit, check for bad wires in cable connector, check for dirt on both connectors' pins).
I hope you can fix it, otherwise just post me some feedback if anything seems unclear, i'll be glad to assist you.
regards
3rq8 (Triarcuate)
1/21/2013 9:11:54 PM • Yamaha Dtxpress... • Answered on Jan 21, 2013
If i hit the ride
Is the 9ch snake cable correctly connected? TOM 3 should be plugged into the 4th input and TOM 1 should be plugged into the 2nd input. (1- SNARE, 2 -TOM, 3 -TOM, 4-TOM, 5-RIDE, 6-CRASH.........)
11/16/2012 6:01:44 PM • Yamaha Dtxpress... • Answered on Nov 16, 2012
4answers
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
11/4/2012 7:15:02 PM • Yamaha Dtxpress... • Answered on Nov 04, 2012
My Yamaha electronic bass pedel is not working. If
There is a piezo sensor behind the pad typically. This can be dislodged or damaged. FIRST check your cables and try plugging the bass into another inout and see if it will trigger that sound. If not, you will need to repair the bass pedal.
SOME pedals have a sensitivity control which is a tiny pot accessable through a hole... this too is easily damaged if wrong type screwdriver is used to adjust it.
be sure and check for a broken cable, especially near the ends.
9/15/2011 6:34:09 PM • Yamaha Dtxpress... • Answered on Sep 15, 2011
Yamaha Dtxpress Iv Special Electronic Drum Set Logo
Popular Tags
85 questions posted
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
dtxplorer
  • Music
