20 Most Recent
Peavey 00511800 Escort Portable Sound System with Stand Questions & Answers
Peavey system
Instead of 140w as suggested, I used 250w now it is not turning on
The green light flashes with
You have a bad power circuit board. if you are tech-inclined,you can open the mixer's rear cover and check for bulging/leaking capacitors on the board. they will need to be replaced. Or just order a new PCB from Peavey. Rodger, in tech support, will be happy to help.
How do I fix the
Open the speaker and either secure the jack or replace it if it is broken... common problem when cables get tripped over.
My peavey escort 2000 system
If after you shut it down and after a while turn it on again and it works the same way. It sounds like a heat problem. We here at Pro Line Music are a Peavey service center. If you can not get any local help you can send it to us.
[email protected]
Hook up extra speakers
Most of these portable PA systems do NOT have amplifiers capable of driving extra speakers SAFELY without risk to the amp.
I would NOT attempt to drive more speakers without using another amp to drive those speakers.
I have a Escort 2000 Peavey P A System. The fan is
It might be giving notice, it might have some loose screws, but then again, it might just need some oiling.
There's probably a sticker on the rear side of the fan (where the power wires come out), remove it, underneath you'll see an aluminium cover near the center. Take this cover off with a pointed knife or similar, it should come off with just a slight force and you should now see the axis fixed in place by a clamp.
You just need to put a drop or so of oil, just make sure it reaches underneath the clamp into the bearing/bushing and if the bearing/bushing was just a bit dry or dirty and if it's not really damaged then the fan shoud now run quietly.
Put the aluminium cover and the sticker back in place, try it out, if it's silent, you win, if it's still giving notice then it should most probably be replaced.
regards
3rq8 (Triarcuate)
The fan is making a noise when I switch the system
As it heats up it is heating the lubricant in the fan bearings which dries out and hardens over time. You can take the fan apart and clean the blades and relube the bearings but it is not easy. It may be easier to just replace it .
Peavey escort
I would try unplugging some of the extras. All of that could have been causing your line voltage to sag too low for the mixer supply to operate properly.
Peavey 14 bt mixer won't pan. Keeps sending signal to both outputs
If your Peavey 14 BT mixer is not allowing you to pan the audio signal and is sending the same signal to both outputs, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can take to address the problem:
1. **Check the Pan Controls:** Make sure you're using the correct pan controls for the channels you're trying to pan. The pan controls are typically knobs labeled "Pan" or "Balance" on each channel strip. Ensure that they're set to the desired positions.
2. **Reset Pan Controls:** If you've already adjusted the pan controls and they're not working as expected, try resetting them to their center positions. This can help eliminate any accidental settings that might be causing the issue.
3. **Channel Routing:** Some mixers have routing options that can affect panning. Check if there are any routing switches or buttons that might be affecting the signal routing for each channel.
4. **Mono/Stereo Mode:** Some mixers have a mono/stereo mode switch that can affect panning. Make sure the mixer is in the appropriate mode for your setup.
5. **Master Pan Control:** Ensure that the master stereo output pan control is set to the center position. If it's panned to one side, it can affect the overall stereo output.
6. **Test Different Channels:** Try panning different channels to see if the issue is specific to one channel or affecting multiple channels.
7. **Firmware/Software Update:** If your mixer has digital components or software control, check if there are any firmware updates available. Sometimes, software updates can address functionality issues.
8. **Physical Damage or Wear:** Inspect the pan controls and associated circuitry for any physical damage or wear that could be causing the issue.
9. **Factory Reset:** If none of the above steps resolve the issue, you might consider performing a factory reset on the mixer. Be sure to back up any important settings before doing this.
10. **Professional Service:** If the problem persists after trying these steps, it might be a more complex internal issue that requires professional servicing. Contact Peavey's customer support or a qualified audio technician for further assistance.
Remember that the exact steps and controls can vary depending on the model of your Peavey mixer. Refer to the user manual for your specific model for more detailed information on troubleshooting and operation.
8/20/2023 2:15:59 PM •
Peavey Music
Answered
on Aug 20, 2023
Does the peavey xr-600b have phantom power
It does not have built-in phantom power. Phantom power is a method used to provide power to condenser microphones and other devices that require a small amount of power to operate.
It is important to note that the XR-600B have XLR inputs which are typically used for condenser microphones that require phantom power but it does not provide this feature. If you want to use a condenser microphone with the XR-600B, you'll need an external phantom power supply or an audio interface that provides phantom power.
1/12/2023 8:34:18 PM •
Peavey Music
Answered
on Jan 12, 2023
Peavey bass R1080052 looking for any info .
Peavey R1080052 is a bass guitar model produced by the Peavey company. It is part of the company's Classic series of instruments, which are designed to offer vintage-inspired tones and aesthetics at an affordable price. The R1080052 features a solid ash body, a maple neck with a rosewood fingerboard, and two single-coil pickups. It also has a vintage-style bridge and a set of open-gear tuners. This bass is known for its warm, punchy sound and comfortable, easy-to-play feel.
1/10/2023 12:11:58 AM •
Peavey Music
Answered
on Jan 10, 2023
