20 Most Recent
General Electric DBXR463EG Dryer Questions & Answers
I have a GE electric
common problem is the rear bearing....http://www.youtube.com/watch?v=U7f8pF64008....copy and paste and watch the video,if this doesn't look like your machine,open the door and if there's two screws on the top remve them and pull off the top panel and everything else will be the same.
DRYER TAKES ALONG TIME TO DRY A LOAD OF CLOTHES IT
You may have a blower which is not circulating enough air flow. You can have heat and no blockage but a blower whcih is not moving enough air to distribute the heat and displace the moisture filled heat to the exterior.
There is no clicking sound
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
No heat dryer
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this
electric no heat tip...
heatman101
Dryer shuting off in 5 min top getting very hot
Is the motor getting hot or is the element not shutting off?
If it is the motor then it is going bad...
If it is the element then the thermostat is bad and will just heat till the high limit shuts it down...then replace the thermostat and the high limit now that it has been activated...
here are a couple of tips that may also help you...
DryerRepair - The
Dryer is not TurningDryer Repair - The
dryer will not startheatman101
When it first starts up it squels for a while,
There is a small plastic T-Bearing at the rear/center of the drum that often wears that could cause the noise.
Easy to replace,but be sure to add a little grease to it before putting drum back in.
At times it could also be the front drum glides,or even the plastic Idler wheel.
Look closely at them all when you have the drum out.
All these parts are relatively cheap to purchase.
Wigo.
center of the drum
A few days ago our tumble dryer begun to make a
that could be anything you just have to unplug the dryer and get in there and see what happened,the belt pulley could have failed and jamming up the belt,first off does the dryer start?if so and the drum isn't spinning then the belt could be broke but this says it's a g.e. dryer so this has a safety switch in it that won't let the dryer run if the belt breaks,also g.e. has a rear bearing that fails,did you hear any sounds before like metal on metal,this could be alot of things,there's a front bulkhead with glides on it,i've seen the drum cut through the front of the dryer before, if you write back send the brand name and model number and anything else you heard before or take it apart and see what's up.if the dryer has alot going on with it don't buy another g.e. dryer get a whirlpool.
