20 Most Recent DeLonghi Stiromeglio Compact PRO 300 Iron Questions & Answers
Heat element light comes on (so there is power) but the iron will not hear up
The Delonghi Pro300 has two thermostats that contact the boiler. One is a low temperature thermostat that allows the boiler to heat up to 145 degrees (F). The other turns off the boiler when the temperature reaches 180 degrees. It sounds like your low temperature thermostat has failed. The part can be ordered on line. You need to have good basic mechanical skills and the proper sized star screwdriver to replace it.
8/23/2014 1:52:18 PM • DeLonghi... • Answered on Aug 23, 2014
0answers
My iron exploded when I plugged it in. How can it be fixed?
You have a short in the wiring inside of the iron. It will not work until you get the short fixed.
10/31/2012 10:54:24 PM • DeLonghi... • Answered on Oct 31, 2012
0answers
Blow a fuse?
Be the first to answer 4/13/2012 4:01:57 AM • DeLonghi... • Posted on Apr 13, 2012Be the first to answer
0answers
0answers
The boiler part is working fine but i have no
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
7/14/2010 3:21:20 AM • DeLonghi... • Answered on Jul 14, 2010
I am unable to stop the steam at the iron. The
I would first try with household vinegar (empty as much water as possible) and if that doesn't work to free the valve, then something more aggressive containing acid like any of the Lime Away type of lime/rust removers. If it is still stuck, you may have to bet the iron hot to make the acid more effective. If using other than vinegar, I wouldn't advise allowing anyone to breath the vapors; do this in a utility room or basement.
That trigger probably acts on a needle valve that controls the flow of water to the point at which it is turned to steam and it may simply be too contaminated with lime buildup to slip back into the valve body.
1/11/2010 1:55:21 AM • DeLonghi... • Answered on Jan 11, 2010
DeLonghi steam iron iron seems to have a loose toggle and the steam is difficult to stop. It will sometimes start steaming with just a jiggle of the iron. How do I fix this?
Question edited for correct spelling of maker name. Question moved from Watches category. Is it older than a year as that is the warranty on steam irons. https://b2b.delonghigroup.com/pdf-warranties/5718114000/5713226531%2011.15/5713226531%2011.15.pdf Have you ever descaled it? It may improve the seals on the buttons. If something has broken inside, it will be time for a new one. Getting inside them is very hard and there are no spares. https://www.fixya.com/support/r26134544-cleaning_laundry_iron ..
5/7/2023 5:59:13 PM • DeLonghi Irons • Answered on May 07, 2023
0answers
0answers
Dirty water
Be the first to answer 1/26/2014 10:05:39 AM • DeLonghi Irons • Posted on Jan 26, 2014Be the first to answer
DeLonghi Stiromeglio Compact PRO 300 Iron Logo
15 questions posted
Popular Products
Top DeLonghi Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a DeLonghi Iron Expert? Answer questions, earn points and help others
View Most Popular
DeLonghi Irons
  • DeLonghi Irons
Most Popular Question
am unable stop steam iron
  • Irons
