20 Most Recent
Nortel T7316E 2-Line Corded Phone Questions & Answers
Caller ID does not display name on Nortel phone
Cell phones do not send caller name, so create a Speed Dial entry for that number with the name you want to see. When a call arrives from that number, the system will show the name you have programmed.
Conference Calls
To establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press feature button then 3.
5. Press the line or intercom button of the first held call (not required on the
T7100/M7100 telephone).
6. Press Release to end the conference call.
To remove yourself from a conference permanently
(unsupervised conference):
Press feature buton then 70. The other two callers remain connected. (Some
external lines may not support this feature. See your system
administrator.)
To put a conference on hold:
Press hold. The other two callers can still talk to each other.
To split a conference:
Press the line or intercom button of one caller to consult privately while
the other caller is on hold. To re-establish the conference, press
To disconnect one party:
Press the line or intercom button of the caller you want to disconnect,
then press Release button. Press the line or intercom button of the remaining
caller to resume your conversation.
I have a Nortel 7316. I have tried an incorrect
To reset your voice mail password,on press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
How do I program time?
Go into the programming mode and scroll down to Time and date. You can change it at that point .
