20 Most Recent
Tempur-Pedic TP4000 Ergonomic Fabric Mid-Back Task Chair, Navy Questions & Answers
How do I lower the back of my chair
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.(This definitely applies to Tempur-Pedic TP4100 Office chair.)
How do I lower the back?
Seat sloped too far forward
You need to be sitting in the chair and the middle lever is the one which releases and secures the angle. I find the adjustment is easier if you release the backrest lever, the third lever to the rear, lean back in the chair which will raise the front seating cushion while moving the backrest back. Using you feet on the floor push back in the chair until the seat feels better. When it is at an angle you like, push the middle lever down to lock the seat in place. Then adjust the backrest with the third lever.
I have a simmons nuflex bed that is fine except the foot wont raise. Massage works on foot, but it just wont lift. No clicking or noises when using the remote
If the foot of your Simmons Nuflex bed will not raise, there may be an issue with the motor or the lift mechanism. Here are a few things you can try to fix the problem:
- Check the remote control: Make sure the remote is properly functioning and the batteries are not dead. Also, check that the foot lift button is not stuck.
- Check the wiring: Check the wiring between the remote, the lift mechanism, and the motor for any frayed or disconnected wires. If you find any damaged wires, they will need to be repaired or replaced.
- Check the lift mechanism: Inspect the lift mechanism and look for any visible damage or debris that may be preventing the foot from raising. Clean the lift mechanism and lubricate it with light oil.
- Check the motor: If the motor is not functioning properly, it may be preventing the foot from raising. If the motor is faulty, it will need to be replaced.
If you are not comfortable with these steps, or if the issue persists after trying them, it may be best to contact Simmons customer support or a professional technician for further assistance. They may ask you to provide your bed's serial number and other information to help troubleshoot the problem.
4/17/2024 2:20:33 AM •
Furniture
Answered
on Apr 17, 2024
