20 Most Recent
Motorola Mobility KRZR K1m Cellular Phone Questions & Answers
Forgot security code for my phone
Take to your local retailer or cellular provider. Provide your proof of purchase and they will be able to reset it for you.
10/20/2013 11:21:10 AM •
Motorola...
Answered
on Oct 20, 2013
Lcd flex cable
flex cables are largely available and easy to replace. post your current location and i will assist you locate nearest store and give you instructions on how to replace the same.thanks for using fixya!
4/23/2012 7:41:08 AM •
Motorola...
Answered
on Apr 23, 2012
Need free download for mobile photos
you mean that you want to download free contents from internet from your phone. Well, for that at first you need to activate GPRS by calling your service provider. activate it after getting settings from them. check that you can connect to internet through it. Now go to this site .Download contents for your phone free !! enjoy. Please vote me if you are satisfied with my solution.
1/15/2012 4:08:54 PM •
Motorola...
Answered
on Jan 15, 2012
Phone unlock codes
I've tried using the free sites to unlock my phone (ex. my Nokia 2600) and I kept getting code errors. Then I found out that my phone was permenantly bricked because of the fake unlock codes that it gave me.
I found out about a company called Cellfservices (http://www.cellfservices.com) and they provided me with a REAL unlock code in a little less than 1 hour. I input the unlock code in my Blackberry and it worked. They are very reputable. I have seen all sorts of sites write about them (Ex. crackberry, blackberry cool, blackberry rocks).
They also give free information on their website about unlocking phones and helpful tips. Very professional company.
5/18/2011 11:25:41 AM •
Motorola...
Answered
on May 18, 2011
I thought I set up
For a lot of carriers, simply calling your own number (what people use to call you) from your phone will allow you to access voicemail.
5/4/2011 12:48:35 PM •
Motorola...
Answered
on May 04, 2011
I have an old motorola
Most motorola codes are 6 digits set by factory.
Try 000000
If this doesn't work. There are a few other methods to try.
1. last 4 of your phone number, or old phone number to the phone
2. last 4 of your SSN or account pin
3/17/2011 8:51:16 PM •
Motorola...
Answered
on Mar 17, 2011
C118 not ringing, on selecting
hi,
try to check maybe your phone is in mute mode or the volume is set too low.
if playing also ringtones, games or your phone doesn't rings when somebody calls you, this could be the problems below.
if it is not in mute mode then most likely it has a defective speaker or
loose connection to the speakers. you can check its connection if
inside if you can open your phone. but try only opening your phone if
you know what you are doing, you might worsten its problem. you can
locate the speaker inside, it is like a small speaker and check if it
has abnormalities. other than that, don't touch anything else.
(if you have a multi-tester, you can check the speaker itself by placing
the red and black probe to each terminals of the speaker and if you
hear a scratching sound on the speaker then your speaker is good. if
none, then an open defective speaker.)
(WARNING: only open if there is no more warranty on your phone cause opening it can cause your warranty to be void)
dont forget to rate me. Thanks...
bst rgrds
John
1/5/2011 7:53:49 AM •
Motorola...
Answered
on Jan 05, 2011
