20 Most Recent Motorola Mobility W510 Mobile Phone Questions & Answers
Hi Emelita Chambers!
To activate the call forwarding option on your phone, please go to:
Menu Button> Settings > Call Forward.
Also, you can check with your carrier the options they have available to enable this feature with your line.
Regards,
Gaby
Motorola Mobility
Motorola... | Answered on Oct 09, 2014
I have a Moto G and the same problem came up after the most recent automatic software update. I use the speakerphone a lot, but it stopped working for no apparent reason. Try turning the volume down (possibly all the way down) and then back up while the speaker is in use. For example, when I make or receive a call and I touch the Speakerphone icon, I then immediately turn the volume down one level and then back up and the speaker works normally. I hope Motorola sends out an update to fix this soon, but, in the meantime, this workaround isn't too bad.
Motorola... | Answered on Aug 04, 2014
Does it stay on when not in a call? If not the battery may need to be replaced.
Motorola... | Answered on Jun 01, 2014
yeap carry on
Motorola... | Answered on Nov 15, 2013
You can get the Motorola W510 Subsidy code from Classicunlocking.com .Here they provide the code with free instruction to unlock from tmobile..To get the code you have to fill the Country ,network name and IMEI number..
Motorola... | Answered on Aug 06, 2013
Usually you press and hold #1 and it will call your voice mail or dial your own phone number and press # or * during your voice mail msg
Motorola... | Answered on Feb 26, 2013
hi :) your were flip phone,flip phone must have a ribbon inside. if it spoil,will made it no diaplay,speaker hearing pro and front display pro. so,your pro may the ribbon spoil already.pls send for technician for repair. Good Luck.
http://www.primustel.ca/en/residential/cellular/pdf/W510_UserGuide.pdf
You should be able to download it from there.
your phone has a virus, there is nothing you can do but get another phone
Motorola... | Answered on Jul 07, 2012
You have the option to change it under display settings in ur main options menu. menu>system settings>display settings>front screen(?)>desplay timmer. This should do the trick. I have mine on 10 seconds and that works great. I hope this helps.
  `Nbryson
Motorola... | Answered on Mar 22, 2012
mam go to the settings>security>automatic keypad >turns off if once this done the keypad will not get locked
Motorola... | Answered on Sep 08, 2011
Each battery type has their service / time limit . It may the time to replace your battery pack with new one. But before decide to replace the battery, make sure your charger is working properly while charging your battery.
Motorola... | Answered on Aug 24, 2011
that means the page you want to open is large.
Motorola... | Answered on Jul 09, 2011
Motorola Mobility W510  Mobile Phone Logo
98 questions posted
Top Motorola Mobility Cell Phones Experts
Lawrence Oravetz
Vernon Taylor
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Cell Phones
Most Popular Question
lost manual
  • Cell Phones
