20 Most Recent Minolta bizhub 350 Black and White Copier Questions & Answers
My biz hub 350, copier, makes a few copies and then stops,displays a message, "pull out this tray and close it again"
which draw? has the paper sensors been replaced? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/10/2018 10:57:45 PM • Minolta bizhub... • Answered on Feb 10, 2018
Is the network card on bizhub 350 found in MFBS board? What does MFBS means?
no. network card is under the scanner section. your network connection is on the right side of the machine below the scanner section but above the section that opens for the duplexer and right side door. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/12/2017 5:57:29 PM • Minolta bizhub... • Answered on Mar 12, 2017
My bizhub 350 still says please wait even the fuser unit & lamp is ok. how do i reflash firmware?
Sir/Mam, Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/12/2017 5:55:44 PM • Minolta bizhub... • Answered on Mar 12, 2017
Bizhub350 toner not feeding
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/12/2017 5:48:46 PM • Minolta bizhub... • Answered on Mar 12, 2017
2answers
Konica minolta bizhub 350 error code c5352
Cooling Fan fault. To clear open and closer the front door. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
10/20/2016 4:00:11 AM • Minolta bizhub... • Answered on Oct 20, 2016
Hi. i have bizhub 350. my problem is the toner hopper is not spinning/rotating. hv already changed the developer,the toner replenishing box and the drum assy, whole unit. what seems to be my problem h
Sir, the toner bottle motor assy. needs to be replaced. will take quite a bit of work to get to, recommended a service tech qualified on Biz hub 350. This series is well known for the toner bottle assy. fault as is the di3510 series prior to the Bizhub 200/300 series. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/10/2015 5:05:49 AM • Minolta bizhub... • Answered on May 10, 2015
Konica minolta 363 error message c-2201
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it is damaged you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/1/2015 7:10:38 PM • Minolta bizhub... • Answered on Mar 01, 2015
How do i add an
User setting, FAX , One touch Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 2:33:49 AM • Minolta bizhub... • Answered on Feb 22, 2015
Please could you help me to reset the mashine, the
Could not find that code in the service manual Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 12:17:32 AM • Minolta bizhub... • Answered on Feb 22, 2015
Our Bizhub 350 has the
Check behind the tray any paper stuck back there? Try swapping the paper from portrait to landscape or vise versa. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 12:14:02 AM • Minolta bizhub... • Answered on Feb 22, 2015
Bizhub 500 fn4 lever pulled down to check for jam,
Recommend you have tech come out and look at it fixing over the internet would be hard. Look for a Konica Minolta Dealership Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/21/2015 10:48:20 PM • Minolta bizhub... • Answered on Feb 21, 2015
replace the toner bottle Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2015 4:47:50 AM • Minolta bizhub... • Answered on Feb 19, 2015
KONICA MINOLTA BIZHUB 750 SHOWING C3503 ERROR
Power off the machine including the one inside the machine. Now with the machine completely off turn on the sub power switch that's one near the control panel, now hold down the Utiltiy/Counter switch and turn on the main power switch then close door keep you finger on the counter button when the screen shows trouble reset touch it goes to OK then power off wait ten seconds before power on. If it comes back get a tech to look at it do not reset because you are dealing with fuser the hot part could catch on fire and that would ruin a perfectly good day. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/15/2015 8:47:02 PM • Minolta bizhub... • Answered on Feb 15, 2015
How to set up smb scanning
2/15/2015 7:53:17 PM • Minolta bizhub... • Answered on Feb 15, 2015
Smb scanning
Go to the web site below Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/15/2015 7:52:59 PM • Minolta bizhub... • Answered on Feb 15, 2015
Minolta bizhub 350 Black and White Copier Logo
75 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
konica minolta bizhub 950 report code c
  • Office Equipment & Supplies
