20 Most Recent
Ricoh Aficio 3025P Black and White Copier Questions & Answers
Sc543 and functional problem
Hello!
This code is related to a Fusing Overheat.
I think the best advise i could give you is to call your technical support.
I'm giving you this advice because it passed two safety systems to cut the fuser overheat. Something very wrong is happening so I tell you that.
Hope this helps!
Error sc542
this show the machine termistor had to be replaced.After you replaced it, you had to reset the machine by going into sp mode
Ricoh Affcios 3025 Functional problem with copier
Hello!
This code is related to a Fusing temperature error.
You probably need to change Hot roller (or fusing roller), Pressure Roller and both thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do not have technical knowledge)
If you still want to reset the code try this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Press "copy SP"
On the key pas press 5810 and #.
On the touch panel press "execute"
Exit all the way out.
Turn the machine off and on.
Hope this helps you
What causes the copy to be lopsided when using the feeder
I'm not sure what lopsided means??? Are you saying that the image is crooked? If you feed the paper 180 degree then the way you are feeding it now, are they still crooked? Also, do the pages get jammed? Also, look to see if one of the hings are broken? If one is broken, it's a dead give away for your problem. If that is not the problem, I would loosing up the screw that hold the adf on and move the adf a bit till the copies come out straight. Once the copies are coming out straight, tighting the adf hing screws and you are done...... Good Luck
Ricoh aficio 3025 copies out of alignment
Check the paper size dials (green dials) of the paper trays that are set to match the orientation of the paper loaded in the tray.
On the touch panel display, select Auto paper select icon and retry.
If the dials are correct and the problem still there, please then try to print the counter printout from the User tools (yellow) button or send a print from your computer.
If still with the copies being cut off, please check for toner spillage between the toner unit and Photoconductor unit.
Open the front cover, pull out these units and clean toner spill.
Clean also the laser shield glass. There is a small cover below the toner supply unit, unscrew 1 screw. Pull out the small glass very careful and straight ahead, pay attention not to break it.
Retry copying and printing.
Good luck and please rate me, thanks.
