20 Most Recent
Canon MF6530 Black and White Copier Questions & Answers
Canon MF 6530 Paper Jams
it can be that sesor flaper in fixing unit has an slow response or the sensor is faulty. Also it can be that this is delay jam due to worn out paper feeding roller, or faulty pressure in fixing assy.
Recommendation is to call service!
My printer's feeding mechanism or
I think that is not problem with your printer,
that is cause paper was moist. and sticky.
solution make the paper became warm (put on the warm place or don't use air conditioner in this room)
Unplugged it and now it
Welcome to Fixya
Try this troubleshooting procedure:
With the machine on, unplug machine from surge protector or outlet. While the machine is off push the Copy, Scan, Start button in that order 3 times. Plug the machine back up. The machine should initialize and be ready to copy.
Please let me know if you have furhter questions.
Thank you for using Fixya!
If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Paper wrinkles up time it gets about an inch in
Hello Hawk.
My name is Jeff and I work for a company named Advanced Office Systems which has been in business for over 30 years.We are based out of Knoxville Tennessee and unfortunately can't come to help.But I feel confident my service manager may be able to help you find a service provider in your area.He's a good man named Dan Llewellyn (pronounced "loo ellen").His number is 865.966.0770 ext 217. A busy man ,but a good man. I hope I have helped you so if you don't mind please acknowledge my help thru FIXYA. Thanx and I wish you the best.
Frequently when I turn on the printer the red
I presume that the problem is in MFP crg. recognition.
When you remove toner crg. on right side in the MFP you will see black "gear" with one metal pin, which goes out when you close the door. Apply small amount of WD40 or similar and open close door for few times. If it does'nt helps you need to dismantle the copier and clean the whole section...
Hope that helps!
By the way didi you try with another crg.?
How do we reset printer to original settings?
press *2 then 8 then *again.machine will be in service mode go to clear,then choose all then press ok
machine will be in default mode,pleaze wait msg will apear,turn off and on again,i hope u will be happy
Will not print
if you have problem, wich is that you have blank copies and prints, the problem is in metal pin caled laser shuter.
Call service.
THE WORD INING COMING ON
Hi
Please can you be a bit more precise about your problem.We will try our best to assist you.
Thanks for contacting fixya .com
