20 Most Recent
Panasonic DP-8035 Grayscale Copier Questions & Answers
How to clear call for p/m fuser web on a panasonic dp 8035
"Call for P/M Fuser Web" (Default: 240K)1. Perform the P/M (Preventive Maintenance). Refer to Section 3.3 and 3.4.2. Press the "Function", "Original Size (Ledger/A3)", and "3" keys simultaneously to enter the ServiceMode.3. Enter the password, and select "OK" button (default password is 00000000).4. Enter the Copy Service Mode F5-73 (Fuser web) PM cycle and change to the desired value.5. Press "Function" and "C (CLEAR)" keys simultaneously to exit the Service Mode.
5/30/2018 7:51:09 PM •
Panasonic...
Answered
on May 30, 2018
How to clear call for p/m fuser web on a panasonic dp8035
not a great idea seeing that the fuser web is needed to clean the hot-roller, so i would suggest to have an authorised dealer replace the web. if however the web has been replaced , and you just need to clear the counter, this is what to do:get into service mode by pressing and holding the "function", "original size" and "3" buttons in rapid succession. sometime a bit tricky.you should see F1 self test on the screen.if not, press the yellow all clear and try again.once in this is what the manual has to say: "Call for P/M Fuser Web" (Default: 240K)1. Perform the P/M (Preventive Maintenance). Refer to Section 3.3 and 3.4.2. Press the "Function", "Original Size (Ledger/A3)", and "3" keys simultaneously to enter the ServiceMode.3. Enter the password, and select "OK" button (default password is 00000000).4. Enter the Copy Service Mode F5-73 (Fuser web) PM cycle and change to the desired value.5. Press "Function" and "C (CLEAR)" keys simultaneously to exit the Service Mode.hope that helps>mario
4/23/2018 10:48:07 AM •
Panasonic...
Answered
on Apr 23, 2018
How will i get the service key oprator mode to
the default key operator mode is '0000' but be very careful what you change in this menu thats the reason its locked so if you not sure about something make another post with details and i'll be able to help
9/13/2013 5:19:42 PM •
Panasonic...
Answered
on Sep 13, 2013
