20 Most Recent Sharp MX-2300N Color Copier Questions & Answers
It means that your fuser unit has reached its lifespan: you can still use the machine but be aware you will need a fuser rebuild in the near future
Sharp MX-2300N... | Answered Yesterday
enter code 20 start 1 start
Sharp MX-2300N... | Answered on Jul 11, 2019
Ok so the DK code means that the Black drum counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 07
Then you can select what you want to clear so the bk drum unit
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
Sharp MX-2300N... | Answered on Apr 08, 2019
F1-00 lost communication with the finisher, check the connection between the copier and the finisher. Shut the machine off, reset the connector then restart the machine.
Sharp MX-2300N... | Answered on Mar 18, 2019
FK3 is the code for the cleaning web in the Fusing Unit.
Sharp MX-2300N... | Answered on Mar 08, 2019
Try reinstalling print driver, or upload a PCL5e driver.
Sharp MX-2300N... | Answered on Apr 01, 2018
The paper exit cooling fan is not working. Reboot machine, if the code comes back, you'll probably have to get the fan replaced. The fan is one of the two located over the right side door.
Sharp MX-2300N... | Answered on Dec 26, 2017
Got in with random trialling passwords for the Administrator... finally found the default password for Administrator on the Sharp MX2300N was "admin". Should have known...
Got in, set up the IP's and away we go again. Did not have to go in with any maintenance mode or re-setting the whole system.
Sharp MX-2300N... | Answered on Nov 25, 2017
The U2 errors are usually related to memory or board level issues. You should try to disconnect the fax and network and then kill the main power inside the cover. Turn the main power on and then when you get a solid green light on the control panel press that power switch. If the machine boots with everything disconected then try conecting the options one at a time and try rebooting each time to see if you can narrow down the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Sharp MX-2300N... | Answered on Oct 31, 2017
probl?me: code error sharp AR-452 U --- H5-01
Sharp MX-2300N... | Answered on Oct 20, 2017
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
Sharp MX-2300N... | Answered on Dec 14, 2016
Try this #, Interrupt,c,interrupt
use the ten key pad type 16 press start
ok
start
interrupt
ca
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp MX-2300N... | Answered on Dec 05, 2016
E7-20 is problem with laser unit - Black. Check connectors, optical axis of laser beam (in case there were assembly / disassembly actions). Laser unit can be defective.
Sharp MX-2300N... | Answered on Sep 03, 2016
Sharp MX-2300N Color Copier Logo
476 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
please fellow technicians problem sharp
  • Office Equipment & Supplies
