20 Most Recent Onkyo TX-SR606 Receiver Questions & Answers
6answers
Onkyo tx-sr606 hdmi problem
Yes the OSD tends to stop working. Here's how to fix it:
http://www.youtube.com/watch?v=gj0x5S9ez5U
9/25/2022 11:52:34 PM • Onkyo TX-SR606... • Answered on Sep 25, 2022
2answers
HDMI signal cuts out for
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
9/21/2020 2:42:27 AM • Onkyo TX-SR606... • Answered on Sep 21, 2020
2answers
No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
5/7/2020 2:32:52 PM • Onkyo TX-SR606... • Answered on May 07, 2020
3answers
Kube 2 subwoofer hum
The Kube Sub-woofer is earthed via its 3 pin plug. The Onkyo and other components I have in my system are not (they are double insulated). During normal operation, a difference in electrical potential can exist between these components in the system. I found that this potential was finding a path to earth via the audio cable and on through the subwoofer's earth. The path was via the earth portion of the audio cable and so gave the hum irrespective of volume levels set either on the Onkyo or the sub.
The fix is to ground the Onkyo to the sub. I used a length of electrical cable between a panel mounting screw on the back of the sub and a screw on the casing at the rear of the Onkyo. Try it out with a piece of cable manually touching screws with the bare ends of the cable until you find ones that give continuity( the hum will go immediately). I then crimped a small fork end electrical fitting onto each end of the cable which can be slid under the slighly loosened screw head and resecured. All I hear now is the fan on the Blu-Ray player!
3/20/2019 10:39:55 PM • Onkyo TX-SR606... • Answered on Mar 20, 2019
No sound with the tx-sr606
This is a problem of DSP. If enter service mode,You will see a picture like this. You can do nothingExcept selling this amp cheaply. This DSP ??????Causes NO SOUND in all channels. Besides, neverBuy 2nd hand onkyo from 5/6/7/805 to 5/6/7/848Series amps. You will suffer the consequences!!!!dsp problem-cul4vjmzkuvncverhuthjcbk-4-0.jpgdsp-1-uogyjvcdpkwkvogd1g1ztygl-3-2.jpgdsp1-uogyjvcdpkwkvogd1g1ztygl-3-3.jpg
3/6/2018 1:12:28 AM • Onkyo TX-SR606... • Answered on Mar 06, 2018
Xbox 360 takes a long time to connect
Hello, I am sorry about your issue. Are your cables longer that 15 feet. If so that could be the issue. Press and hold the game button for several seconds. It should change back to game. Thank you, Onkyo USA
7/6/2017 4:43:16 PM • Onkyo TX-SR606... • Answered on Jul 06, 2017
Receiver will not recognize HDMI input for sony
Hello, I am sorry about your issue. Have you tried the other inputs on the receiver? Thank you, Onkyo USA
6/13/2017 7:02:44 PM • Onkyo TX-SR606... • Answered on Jun 13, 2017
Onkyo 606 Video Drop out
main board fault, its input feed on the board might be failing, it could also be a failing capacitor, you would need to open it up to have a look and see if there are any capacitors failing.
5/14/2017 5:59:13 AM • Onkyo TX-SR606... • Answered on May 14, 2017
No component video with my
Hello, I am sorry about your issue. Did you make any changes to the output resolution on the Wii. The output must be at 480i for the receiver to up-convert to HDMI. If there is a problem with the receiver I suggest a work around by connecting the component [red,blue,green] video outputs to the TV and the audio connections [red, white] to the receiver. Thank you, Onkyo USA
5/11/2017 5:01:34 PM • Onkyo TX-SR606... • Answered on May 11, 2017
AVR 141 HDMI Video + Direct audio
Hello, please contact Onkyo at 800-229-1687 option #3 so that we can review your setup. Thank you, Onkyo USA
4/12/2017 4:47:52 PM • Onkyo TX-SR606... • Answered on Apr 12, 2017
Random HDMI audio and video drop out & video noise
Hello, I am sorry about your issue. I suggest that your receiver be looked at by a service center. Thank you. Onkyo USA
4/4/2017 6:46:19 PM • Onkyo TX-SR606... • Answered on Apr 04, 2017
I've connected my laptop and
Hello, I am sorry about your issue. It sounds like your receiver needs to be serviced. Thank you, Onkyo USA
4/4/2017 5:22:49 PM • Onkyo TX-SR606... • Answered on Apr 04, 2017
Onkyo tx-sr 606 HDMI signals not working anymore...
I am sorry about your issue,. If the reset did not resolve your issue the receiver would need to be serviced. It if was purchased from an authorized seller less than 2 years ago it would be under warranty. Thank you. Onkyo USA
3/21/2017 4:54:53 PM • Onkyo TX-SR606... • Answered on Mar 21, 2017
2answers
How to reset reciever
If you can't resolve the issue yourself, try resettingthe AV receiver before contacting your Onkyo dealer.To reset the AV receiver to its factory defaults,turn it on and, while holding down the [VCR/DVR]button, press the [ON/STANDBY] button. "Clear"will appear on the display and the AV receiver willenter Standby mode.Note that resetting the AV receiver will delete yourradio presets and custom settings.
5/9/2016 12:16:21 PM • Onkyo TX-SR606... • Answered on May 09, 2016
WHEN I ON ONKYO SR601 , THE UNIT ONS I CANSEE THE DISPLAY, IT EVEN WARMS UP BUT NO SOUND, I EVEN TRIED TO RESET THE UNIT BUT NOTHING, PLZ GIVE ME SOME TIPS
There is a Onkyo recall or service program being offered. I'm not sure if your unit is included, but here is a site to check the serial number to see if it's qualified: https://repair.onkyousa.com/na This is posting on the AVS Forum board : http://www.avsforum.com/forum/90-receivers-amps-processors/1652514-onkyo-acknowledges-failed-units-extending-warrranties-until-2018-a.html
2/7/2016 10:36:02 PM • Onkyo TX-SR606... • Answered on Feb 07, 2016
No sound from new sony uhd tv on the Onkyo sr606 receiver when watching smart content like netflix.
Hi AB, best way to accomplish this would be to go from the TV's audio output to any open audio input on the 606 and just be sure that you assign the source to the input. If you require further assistance please feel free to give us a call at 800-229-1687, also note that we offer a trade in program if you are looking to upgrade to a newer receiver, please email me your current units serial number and I will advise if it qualifies for the program. You can email me at [email protected], Thanks, JT
1/11/2016 4:13:40 PM • Onkyo TX-SR606... • Answered on Jan 11, 2016
Onkyo TX-SR606 Receiver Logo
322 questions posted
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
kube 2 subwoofer hum
  • Audio Players & Recorders
