20 Most Recent
Yamaha RX-V463 Receiver Questions & Answers
No power supply coming in ...
To initialize and reboot the unit, hold down the Main Zone power button for more than 10 seconds. Hopefully this will allow you to turn on the unit.
I can't get the video to work on the wii using the
Your post indicates the use of a receiver. If you are in fact using a receiver, make sure you have a "video out" connection from the receiver to your television. Then make sure you have the correct input selection on the receiver, and on the TV.
Yamaha Receiver RX-V463
Do not use HDMI thru your receiver. Go directly from the Cable box to the TV. Connect coaxial digital or optical to your receiver. Your receiver uses HDMI version 1.1 or 1.2, which is riddled with issues. If you want to read about them, Google HDMI Problems and you can read for hours. Long of the short of it is; Don't pass HDMI thru your receiver, use the receiver for audio only. Hope this answers the question. Sorry for the bad news! I'm in the industry and have been dealing with these issues for a couple years now.
Direct TV remote code for yamaha rx-v463?
It is 30376. The trick to discovering, is to turn the receiver off, first. Then it will power on when you input mute/select 30376. Then you can program the DirecTV remote to adjust volume (in AV2 mode only or in all modes). However, it will only power up the receiver. It has to be turned off with the original remote or at the receiver itself.
How to use sap with a rx-v463?
the trick is, it has NOTHING to do with your receiver, and EVERYTHING to do with your TV, you need to choose SAP on the TV not the stereo. That will send the SAP sound to the stereo you are playing the sound through.
